Matching a pair of older Dinotte V's with 18650's- Mtbr.com
    Hey, I figured this was the right forum (not DIY) to ask this.
    I have a pair of the original Dinotte Luxeon V's that I've been running with home brew battery packs made of 4 nmih "a" size batteries. (never been able to get 4 AA's, not even brand new ones hot off the charger, to sustain high setting for more than a few seconds without activating the red light. The A size did and fit Dinotte's nylon holder and were dirt cheap surplus.) anyhoo, they're spent now.
    So I have 16 18650's cannibalized from some surplus Dell laptop batteries, all are good. I can't for the life of me figure how to get their 3.7-4.0 volt output to match up optimally to the Dinottes. What's the max voltage the Dinotte V will accept? The 18650's are never more than 4.09 off the charger but I wouldn't dare give one module 8.18v unless I am sure they will be safe, and I think they are not satisfactory performance at 4.0 or so.
    (I hooked up one module to a 18650 and one to a functional 4x A which runs about 5.27v off the charger, not sure if the output from a 1 18650 scheme is downgraded because of current or voltage limitations.)
    Anyone with any ideas? The two dinnottes in some kind of series circuit scheme? a certain sized stout resistor stepping down the 8.18v? anything?
    All bikes weigh 50 lbs. a 50lb. bike doesn't need a lock. a 40lb bike needs a 10lb. lock. a 30 lb. bike needs a 20lb. lock.
    My $0.02.....rig your 18650's into a 7.4 volt configuration and hook it to one of these..> http://www.batteryspace.com/dc-dcreg...dc1ampmax.aspx
    Assuming of course that the old Dinotte V will run off of 6 volts and use no more than 1A. Battery Space also sells a 7.4 volt battery using the same voltage regulator already built in FWIW. I bought one some time ago to run my standard 200L off of and it worked fine. The only down side is that the regulator will drain the battery down to a set cut-off point, even when not being used. ( Now if you install an in-line switch between the battery and the regulator that problem would be eliminated. ) If not it's no big deal, you just have to remember to charge the battery just before you plan to use it.
    Quote Originally Posted by Cat-man-do
    Hey that first idea may be on the right track.
    I have a dc bench power supply with adjustable voltage and current (BK1621A as if anyone cares) and it has digital readout, kinda neat if you want to see how much a device is hungry for.
    I tested the light heads and at a regulated 6.0vdc they want .65a on low, .97a on high. As that is a little less margin than I like and I will always use both at once instead of getting 2 of those I'm thinking one of these instead:
    http://www.batteryspace.com/dc-dcreg...o6vdc-01v.aspx
    Same 6v output but rated at 5a max load. See any issues with that? It gets me off $5 cheaper and $$ is an issue thanks to GreatDepression.2
    So far this is the best idea.
    Oh, I see. You want to run two off of the same battery. Yes, the 5A version is better if that's the case.
