Magicshine Durability?- Mtbr.com
Results 1 to 15 of 15
    I love all of the MS threads! My concern is this. I have head light and tail light and they both mount the same way, with the cord placed too close to the o ring when it's mounted. I change to a different o ring size daily and I am worried that this will cause durability issues with the cable going into the light. Does anyone have any long term use in this type of condition with either the head or tail light?
    Thank you.
    Chris
    I too have wondered the same thing, since the O ring bends the power cable.
    I bought one and the charger system failed within a few days. I just went with the Lupine Betty II. I considered keeping MS as a secondary light for another bike, but not impressed with the battery holder or charging system. Lamp is really not too bad for the price. If I got one again, I would just consider just the lamp itself and build my own battery pack and use a better charger.
    I am having issues getting my refund processed. The unit was returned over three weeks ago and still waiting for CC refund. Contacted GEOMAN 8/28and they said would refund, but still not showing up yet. A little concerned and seems unduly long and not the great customer service I was expecting from forum comments.
    Pimpmobile
    Wow...
    I guess you decided to drop some coin, huh?
    VERY surprising on the Geoman customer service thing... I had a warrantee rerplacement within two days.
    "Fear not the ob-stackles in your path"
    Quote Originally Posted by HamfisT
    If he'd gone with a warrenty replacement, he probably would have had that in 2 days too, but perhaps a credit card refund takes longer (on the banks end).
    Quote Originally Posted by ctxcrossx
    I'm curious why you change the O-ring size daily? I don't follow?
    Anyway, you can look at post #11 in this thread to see if they might work for you.
    Mar 2006
    I have the MS 900. I've never used the supplied o rings. Instead, I use an old Sigma sport o ring which is a little thinner so it doesn't interfere with the power cable.
    Quote Originally Posted by fightnut
    I mainly change out the tail light as that gets used more. I have a one year old son and we go out in the bike trailer or running stroller daily. It really helps with visibility on the road. Sometimes both, so it moves depending on which we are using. I also commute by bike, so it gets used there as well. It's not uncommon to move the tail light 2-3 times a day.
    I was worried about the wear and tear on the cable going into the housing, which happens to be identical with the headlamp. I do have a solution for both parts though. I'll try to post an update tonight.
    Chris
    Dirt Deviant
    Reputation: savagemann's Avatar
    I had a handful of some niterider o rings. I use those as they are smaller and you dont have to bend the cable up to get it in there.
    I also modded my 1400 with a marwi mount so I completely ditched the o rings on the bars. Mount works great.
    Look, whatever happens, don't fight the mountain.
    Wow...
    Not as much as you would think, I got a good deal. But still several times morel
    Maybe I am the first to ever return one. I actually did consider keeping it, but the darn thing charged once and then just nothing. I just noticed over in the bike rack forums some comments about 1UPUSA and its bad customer service. Just the opposite on my several interactions and have have been extremely pleased. Perhaps we suspect too much of these smaller companies. They probably have limited staff with schedule/vacations issues. What looks bad to us, if probably their best they can do with limited resources.
    Chunky Monkey
    Reputation: circusubet's Avatar
    Still Going
    Had my MS since '09 and still going strong......
    Thx,
    John
    Lurkers Unite! Never mind....
    Reputation: TwoHeadsBrewing's Avatar
    I've run my MS900 since last October, commuting through the winter rain or shine. I've also used it a dozen times so far this year on MTB night rides and it's stood up to that as well. I even crashed with it on my helmet and it still works fine. I've had zero problems so far, and the battery life is still good.
    On that topic, how good are the 81650 cells in the MS battery packs? What's the expected life of those types of Lithium Ion rechargeables?
    "Got everything you need?"
    ol' dusty lungs
    Reputation: the sloth's Avatar
    Purchased in October '09... went to fire it up this year and light would shut off unexpectedly... tracked it down to a bad connector on the battery pack.
    Reputation: Pitto's Avatar
    first proper use this morning of my MS900 and i must say, its a great value light.
    i used it solo helmet mount, and found it to be great, but i feel, it should be paired up with a
    bar mounted one also.
    still, it does the job. just need to get some spare o-rings from the bearing shop and chuck them in the hydropac.
    Chunky Monkey
    Yep
    Quote Originally Posted by Pitto
    P-+1
    Thx,
    John
