MagicShine 900 charger question...- Mtbr.com
Results 1 to 6 of 6
    I just bought a Geoman MS 900. I used if for the first time today. Rode about 45 minutes with it on high. When I plugged my battery onto the charger tonight, the charger LED is primarily green with a flashing red. Is this normal? I assumed it would be red until fully charged, then go to green.
    I have two batteries (one I have not used yet) and the charger indication is the same on both. I also tried connecting the charger with and without the extension cable. Charger LED is still green/brinking red.
    James
    08 CDale Road Tandem 2
    07 Stumpjumper FSR (wife's)
    06 Spec Roubaix
    06 CDale Synapse (wife's)
    04 Spec Enduro
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    I have the same problem with my new charger. I think there must be a loose wire somewhere, because I am sometimes able to make it go away by squeezing or tilting the charger a certain way. Very hit or miss. I am going to be writing to ask for a replacement.
    Mar 2006
    Mine did the same thing until it went green I assumed it was normal.....
    Cars Are Evil
    Reputation: Vermont29er's Avatar
    Contact Geoman about it, they'll help you out. Mine did the same thing. I got a reply very fast.
    Geoman Sending new charger
    Quote Originally Posted by Vermont29er
    Already did. They are sending a new charger. They responded a couple hours after I e-mailed them. Thanks.
    James
    06 Spec Roubaix
    04 Spec Enduro
    Funny I just pm'd them about mine too!
    Got home Went to charge it. Blinky lights. Contacted them, came on here and found you all talking about it.
