Magic Shine: P7 vs. XM-L- Mtbr.com
Results 1 to 2 of 2
    Mar 2005
    I'm trying to decide whether to spend the $55 via Geoman and get the XM-L Magic Shine to replace my P7.
    I'm having minor trouble with the switch, as I have to push it very hard to turn it off/change modes. I find this irritating because there is no thermal limit protector in my P7 and I often have to stop for long enough that I have to turn off my light. I've read the new XM-L is not only brighter, but has a wider beam and noticeably more throw. It also has a better flash mode and thermal limit protector so I wouldn't have to worry about turning it down/off.
    I'm wondering, is the run time about the same with either?
    If I get the XM-L, I'll also get the Y-cable in case I want to run both.
    If anyone has both, can you post your opinions and possibly some pictures?
    Thoughts?
    I have the Geoman version of the MS808E. It is an excellent light. Run times on high should be a little better than the original P-7's. However you might find that the mid-level on the new 808E will give you almost as much light as the high mode and should extend run times ( with good visibility ) even more. The new mode menu set-up on the Geoman version works very well. Because the flash mode is on a separate menu you don't have to cycle through flash when you change modes.
    As for running the light when stopped; This is never a good idea, thermal limit protector or no thermal limit protector. Depends of course on how long you're stopped. At a traffic light you should be fine. If you're stopping for more than 5 minutes I would either power down to low or turn it off. Thermal limit switches are basically there for safety sake. Like the low voltage cut-off switches on your battery, you really are better off not testing their limits if you can help it. To sum up: turn the light to low ( or off ) when resting and plan your night rides based on how much run time your battery has. Need I say, a second light or torch for back-up is always a good idea.
  1. Magic Shine issues
    By 28/29 WIT in forum Lights and Night Riding
    Last Post: 07-12-2011, 04:01 PM
  2. Magic Shine vs. Others Lights?
    By AceMulder in forum Lights and Night Riding
    Last Post: 07-05-2011, 12:10 PM
  3. Magic Shine UK
    By Goldigger in forum Lights DIY - Do It Yourself
    Last Post: 02-10-2011, 06:42 AM
  4. magic shine needs help
    By stingray66 in forum Lights DIY - Do It Yourself
    Last Post: 10-06-2009, 04:17 PM
