Lupine Tesla Question- Mtbr.com
Results 1 to 7 of 7
    So I bought a Tesla 4 maybe around a year ago. Love the light, huge step up from my NiteRider Tri Newt. There's one little issue though:
    The light, even when fully / freshly charged, will occasionally "blink off" while I ride. It usually happens after maybe 40 minutes or so, but it isn't totally consistent It's a really short pause. I see nothing in the manual about this, what does it mean?
    Todd and the good folks at Gretna Bikes have been awesome to work with. They've even replaced my charger for me (I have the Micro Charger). I hate to keep bothering them though, at least not till I understand whether I have a problem or not. The blink is really only a minor nuisance as I typically run another light on my bars with the Tesla on my helmet.
    The only things I can figure are that the light is "telling" me that either the battery is low (shouldn't be though, it's supposed to run over 2 hours on high) OR that the lamp head is too hot (but it's happened in sub-freezing fast paced rides with few or no stops).
    Any ideas? Thanks.
    Feb 2006
    If the button turns red (from blue) then it is the low battery signal. On the basic model it is set to too high of a voltage (7.5V?) so it kicks in way too early. The later model (Tesla SC) is programmable, so you can lower this threshold.
    So far as I can tell, the button isn't turning red. Then too though, it's mounted atop my helmet, so the button is rather difficult to see whilst riding...
    What about the light flashing off? Do other Tesla owners have similar experience?
    Feb 2006
    I meant: the light flashing AND the button turning red. Check it next time you see it flashing... it stays red until you turn the light off.
    Quote Originally Posted by radirpok
    Got it, thanks.
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    mine has done so when switching to "low" battery and a different more fast pace I think before going off (before turning reserve)
    Mine too
    There was a thread awhile ago about this same behavior. The OP said it might have been related to Moisture inside the unit. Mine had done this during my rides last season, but haven't got out this year yet. I have opened the unit to let air on it for a day or so. Well see if this has helped this season. I do notice alot of moisture on the inside of the lens when the lamp is on full blast. Well see what happens this year. Still love the light , blows away my NR HID.
    High Ho Sultan, Lets GO
