OK so I finally got neutral white pike and wilma from Lupine North America. Problem I am having with the Piko is that it will not tighten in it's mount. If I tug the cord the light turns up and shines in the air. I talked to Dan and sent the light in for them to look at. Was told that they put it in a new mount and operates as it should. I got it back and it exactly the same.
Is this normal? I would think that it would tighten in it's mount so that it does not move. Just does not seem right. Turning it on/off moves the light in the mount. Not much but it does move.
Wilma is mounted on the QR mount and it is rock solid. They did provide extra washers but the screws are not long enough to use them.
Thanks, Norm
