Lupine Betty x pro bezel question- Mtbr.com
Results 1 to 2 of 2
    Aug 2015
    I just picked up an older lupine betty with the upgraded led board but it came with a loose o-ring in the box and it fits inside the bezel. Question is do i put it between the bezle and the glass or behind the glass in front of the lens? Thanks for any help
    Reputation: MaximusHQ's Avatar
    Did you get the Betty with the external switch? If I recall correctly the older lupine betty upgrade kit might not require that o ring. I think the upgrade board made it thicker and not able to fit the o ring in there so lupine called for not using it. I could be wrong though so better to shoot an email to lupine or lupinenorthamerica and see what they have to say. This video shows someone upgrading a lupine Wilma which uses the same o ring setup and you can see the o ring location in his video in case you do end up needing to use it. https://www.youtube.com/watch?v=LZhoY-FQuVs
  1. new RAVEN vs. LUPINE BETTY
    By czarny_kruk in forum Lights DIY - Do It Yourself
    Last Post: 01-13-2012, 07:31 AM
  2. Lupine Betty 12
    By Andy Pancroft in forum Lights and Night Riding
    Last Post: 11-21-2011, 11:51 AM
  3. Lupine Betty for Helmet?
    By phidailo in forum Lights and Night Riding
    Last Post: 10-10-2011, 08:56 PM
  4. Lupine Betty - 22 or 26 degree?
    By blaadd in forum Lights and Night Riding
    Last Post: 09-27-2011, 07:20 PM
  5. Lupine Betty 7 22 degree
    By RBrady in forum Lights and Night Riding
    Last Post: 02-01-2011, 06:18 AM
