Look what I just got...- Mtbr.com
Results 1 to 17 of 17
    Smile Look what I just got...
    Diablo Mk.2
    From the few rides I had with it, it looks amazing.
    The beam is even and very bright...900 LUM it is light weight and...It comes with a full two year warranty
    The down side is the burn time, therefor I'm using the 3 Cell PiggyBack to get
    around 4 hours and 15 Min with it.
    I'll get some beam shots soon and I will upload as soon as I can.
    Cheers
    Attached Thumbnails Attached Thumbnails Look what I just got...-img_5449.jpg
    Reputation: Baja Designs's Avatar
    Aug 2010
    I likey! Where did you get yours Eran? Perhaps Baja Designs should make a deep-sea capable version like the Strykr series? I have always been a fan of these guy's products.
    Well
    I got it from a local dealer in IL....same price as in the UK.
    Aug 2010
    Quote Originally Posted by eranpeled View Post
    Excellent...time for a little dissection...
    I'm just curious, what's up with that "smart port" in the back? Does it have a cap of some sort? Isn't water going to get in and short-circuit the thing? What's the deal?
    No cap...
    Quote Originally Posted by Azra View Post
    Good point you got here...no cap...Lucky me, I live in a dry area
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have that same light and a Toro on my handlebars. I love them.
    I like turtles
    Just curious....How do you find the weight? I mean, really...the thing is big. I have torches that are smaller than the Diablo and "they" give me problems.
    Weight is no problem Cat. With a little neck harness training, you'll be good to go!
    I don't feel it at all...!
    Okay, not so much the weight issue then. I suppose it depends on the rider and what helmet they are using. My helmet is some what old and so is not so tight fitting anymore.
    If I put too much weight on it there is a tendency for the helmet to slide around a bit. Not to mention sweating doesn't help this. Most of my lights and mini-torches work fine. The bigger torches have caused me some problems in the past. I did just replace some front padding so maybe I might have to revisit the large torch issue to see if there is an improvement. Thanks for the feedback.
    turtles make me hot
    The Diablo is not heavy and not having a battery with a wire in my camelbak is a huge plus.
    I like turtles
    But...
    Quote Originally Posted by NYrr496 View Post
    If you need a burning time longer then 1.15 h, you will have to add the PiggyBack.
    turtles make me hot
    I have it. I run both of my lights on medium. Haven't had a problem yet. My night rides are about 2- 2 1/2 hours in duration.
    I like turtles
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    Diable Mk2, a GREAT light
    I've got one too HERE
    Just ordered mine but I am wondering whether it comes with a handlebar mount??
    According to the owner's manual it doesn't seem to be included:
    https://www.exposurelights.com/uploa...manual_pg3.jpg
    However, according to MTBR's review, both the helmet and handle bar mounts will be included.
    I will be using the Diablo primarily as a helmet mounted light but it would be nice to have the option to have it mounted on the handle bar should the occasion arise.
    It dose not come with it but...
    You can use this one...I tested it and it's 100% safe
