I like a number of the features of the Lezyne KTV rear light, it is small, bright enough at night, USB recharges w/o the need for a cable, mounts real simple and easy, but unless it is mounted near vertical much of the light intensity is wasted.
I thought I'd pass on a mod which works well for me. One way the light can be mounted is with the included o-ring around the seatpost, but it aims at the angle of the post, downward. So I got out my dremel and sanding drum and ground an angled scallop at about 18 degrees at the diameter of the post.
Not perfectly vertical but much better and still simple. And it can still be used in clip-on mode for backpacks, etc.
