I'm looking for a low cost helmet mount light.- Mtbr.com
    Waded through some of the Cheap Lights 2020 post but there is too much scattered info.
    I'm looking for a helmet mount light and hoping to keep it under $150. If I can do it for less all the better. I have a Lumina Micro 850 that I will carry for backup so willing to take a bit of a gamble on some lower cost (read Chinese) options.
    Ideally it will have a spot beam, 1800+ real lumen output, 2 hour run time, go pro mount, be water resistant, reliable and not break the bank. I'm fine with a external battery pack.
    What are some good options?
    Reputation: MRMOLE's Avatar
    What are you using as a bar light? 1800 real lumens from a light that has an appropriate helmet spot beam and weight may not be possible for your budget. I'll see what I can come up with depending on you bar light info for compatibility.
    Mole
    Aug 2005
    Gloworm Alpha Mole? Obviously not 1800 lumens but fits the rest of the spec...
    Quote Originally Posted by MrGT View Post
    That's probably the best choice for someone wanting to carry the battery on their helmet. X2 lightheads are only $129 @ Action-LED-Lights + a $30 6800mAh ebay battery would only blow his budget by $10 and give him just under the requested 1800 lumens. Throw of the 2 lights is pretty similar but extra power and wider beam of the X2 might come in handy depending on what's used for a bar light.
    Mole
  1. Replies: 8
    Last Post: 03-24-2016, 03:06 PM
  2. Folsom Lake is Low Low Low
    By Tripower in forum California - Norcal
    Last Post: 12-02-2015, 08:33 PM
  3. I have an e thirteen 1x low clamp mount and an mrp 1x low clamp mount
    By isignay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2013, 08:46 PM
  4. One light - bar mount or helmet mount?
    By BarryGXNZ in forum Lights and Night Riding
    Last Post: 11-05-2012, 04:26 PM
  5. Light bike - low cost.:D
    By Rallyator in forum Weight Weenies
    Last Post: 09-23-2012, 07:12 AM
Members who have read this thread: 59
