Headlight Mount for Up in the Fork/Head Tube?- Mtbr.com
    Oct 2017
Size:  66.6 KBI have one bike that has a fender mounting hole up in the fork, smack dead center of the head tube (the threads going north "into" the head tube). Does anyone know of a standard headlight mount that could use this position?
    I have a few of the "fork crown" mounts on other bikes with standard fender mounts. and they do a good job of keeping the bright beams on the road instead of the eyes of annoyed drivers and fellow cyclists. I wish the same when riding this bike...
    Thanks in advance!
    That is a French-style fender mount. There are a couple of ways of getting the same thing going, depending on the bike:
    -a 'daruma' mount--a draw bolt (cantilever pad bolt) mounted with a long 6mm screw run through the front/rear holes on the crown. When something is then mounted that spans the hole on the bottom, a nut will draw the assembly tight. Obviously, a bike that you can do this on already has crown holes, so it's really only doable for rack or fender mounting.
    -knock a star-fangled nut in the bottom of the tube. You'll need a smaller size, in all likelihood, than a 1-1/8, as the bottom of straight steerers are internally butted 9 times out of 10. 1" nuts should for most steel steerer tubes.
    -SKS makes an expanding plug mount for some of their fenders that I'm sure couple be repurposed here...but am unsure of any 100% solutions for a tapered 1-1/8 - 1-1/2 steerer.
    Sep 2017
    Idea!
    Quote Originally Posted by michaelm101 View Post
    The image shows the Supernova Multimount - why not getting one of these?
    shop.supernova-design.com/shop/category/accessories-multimounts-29?search=Multimount
    May 2005
    If you have a light that is compatible with the GoPro mounting system or a light that can be converted to GoPro mounting with one of my adapters, I could have a solution for you. I could make a modified version of my fork crown GoPro mount that would attach to your fork steer tube hole.
    http://forums.mtbr.com/lights-night-...r-1030516.html
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
  1. Olight S2R headlight with 3D printed Mount
    By legopro87 in forum Lights and Night Riding
    Last Post: 01-28-2018, 12:45 PM
  2. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  3. Fork crown headlight mount
    By djork in forum Commuting
    Last Post: 09-20-2012, 12:00 PM
  4. 2012 Air9 Head tube / head set questions
    By Nooge in forum Niner Bikes
    Last Post: 12-27-2011, 03:51 PM
  5. Fargo/Minimalist headlight mount
    By WTB-rider in forum Salsa
    Last Post: 06-23-2011, 04:45 PM
Members who have read this thread: 7
