Gopro Compatible Light Heads?- Mtbr.com
Results 1 to 11 of 11
    I'm looking for a new helmet-mount light for the season. I've found I don't really like the weight of the all-in-ones shifting my helmet around. I don't really understand why most of the industry seems to be shifting to all in one units.
    So to sum it up my criteria are...
    1. Gopro style mount
    2. As lightweight as possible
    3. At least 700 lumens
    4. Round battery connector
    Thanks for the suggestions!
    Reputation: TMWTP's Avatar
    Nov 2015
    I had to 3d print a go pro adapter for mine. :/
    Sent from my SM-N950U using Tapatalk
    Reputation: RS VR6's Avatar
    650...50 short of your 700.
    It has a round plug 4.2v and a USB 5v connection.
    Image in the listing shows one connector...but it has two.
    https://www.aliexpress.com/item/3289...13f54c4d8jCeDt
    Attached Thumbnails Attached Thumbnails Gopro Compatible Light Heads?-img_20191009_200957.jpg
    May 2005
    Shameless Plug mode on......
    Buy the light that hits your preference for beam type, output, weight, etc. and don't worry about the mount. Convert it to GoPro mounting to get the mount you want. I make GoPro adapters for a pretty wide variety of lights.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Nov 2016
    Hard to find such light heads.
    I constructed a 3D printable adaptor for KD2 head of Kaidomain that might meet your demands:
    https://www.thingiverse.com/thing:3929510
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Using 2x Cree XP-L High Intensity or Cree XM-L2 LED's
    Aluminum GioPro adapter by vancbiker
    light head measure 2 1/8" long x 1 1/2" wide x 3/4" tall
    light head alone weighs about 70 grams
    2 wheel drifter
    Reputation: blackbart's Avatar
    The lupine lights all have the option of a GoPro mount. The lamp head is 150g for the Wilma, which is perfect as a standalone headlamp. They do however use their proprietary connector style.
    i have a lezyne 1250 light with a builtin battery that i use for my helmet light. they make a gopro mounting bracket for their lights, pretty much unscrew the stock rubber bar mount, and replace it with the gopro mount, done.
    2017 yeti sb6c turq x01 eagle
    Dec 2018
    Quote Originally Posted by rusty904 View Post
    Since you didn't specifiy your price range: gloworm x2? Comes with a GoPro Mount, >1500 lm, and comes with a remote. It comes also with three different optics, so you can adjust the beam pattern according to your needs.
    And you probably know the Outbound Hangover thread? 800 lm, 100g, internal battery, allows charging while in operation, so a USB powerbank does the job to extend runtime.
    Quote Originally Posted by blackbart View Post
    The lupine connectors are not proprietary, these are molex 1625 connectors. Not so easy to get, but doable. The easiest way would be to buy a lupine extension cable, cut it and the connect a round DC5521 plug or cable to it.
    Nov 2017
    Quote Originally Posted by scar View Post
    Great idea! I want a setup light that.
    Reputation: Wombat's Avatar
    Quote Originally Posted by raaden03 View Post
    Then you're in luck as Scar sells these!!
    Tim
  1. GoPro Compatible Light Mount?
    By CJones in forum Lights and Night Riding
    Last Post: 03-27-2017, 08:41 PM
  2. Heads in, heads out on rim lace?
    By flyxaos in forum Wheels and Tires
    Last Post: 03-14-2013, 04:06 PM
  3. Replies: 12
    Last Post: 12-08-2011, 09:36 AM
  4. heads up fellow video heads
    By eraSSerhead in forum California - Norcal
    Last Post: 06-14-2006, 11:24 PM
  5. Heads-in or Heads-out on radial front road wheel?
    By jbf in forum Wheels and Tires
    Last Post: 01-28-2004, 05:50 PM
