Eyewear for night riding- Mtbr.com
Results 1 to 11 of 11
    This forum seems to be mostly about the lights. But I want to talk about another essential piece of equipment for night riding: Your eyewear.
    I use the following with clear lenses and they seem to work well for most conditions:
    Where they don't work well is in severe fog. I ride in SoCal in the early mornings and there is often fog/low clouds clinging to the hillsides. When I ride through one of these fog banks, a lot of moisture condenses on the lenses and they are generally useless for the rest of the ride.
    So, what are your experiences? Do you have any glasses that you recommend given the above conditions?
    I wear perscription glasses, so just use a pair of persrciption Oakley A wires with clear lenses for low light riding.
    I'll check them out
    Quote Originally Posted by billysan
    Anyone else have some favorite glasses that work in the fog?
    she keep you buying rats
    Reputation: WeakMite's Avatar
    In the last few years I've noticed that some brands inexpensive safety glasses have really improved their optical clarity. After I left my Oakley Zero clears on the roof of my Jeep last year I've been using AO Safety's Virtua model clear glasses.
    A trick for anti-fog... (I just learned of this one from a scuba forum) is to rub on some shampoo on the lenses and let dry, then buff off. They won't fog up for 2 or 3 weeks.
    Nice!
    The glasses I mean....
    Uvex also makes great safety glasses with a very good anti-fog coating. I have been using them for years at night and all winter long. Also when I use the table saw! Several models work. I am currently using the ignite and Genesis on occasion. http://www.uvex.us/products.aspx#/folder=98
    urmb
    urmb.org
    Reputation: rabidchicken's Avatar
    Smith Reactors with clear lenses.
    I have a pair of Sette Vexx's from Pricepoint... they are fantastic, come with 3 different color lenses (clear, orange and black), have a fanstastic case they came in... and are cheap at about $20
    ^^^^ I use those Sette Vexxs too and have good results and really like those interchangeable lenses.
    A plethora of pinatas
    Reputation: mcoplea's Avatar
    Oakley Radar's with the clear vented lens work awesome for me!
    Marty
    It ain't easy being Green
    Reputation: sdcadbiker's Avatar
    Another Oakley fan here; a dab of spit on the lens helps reduce fogging and if it gets too bad you simply tap the edge of the lens against your arm and the water falls right off due to the special coating. Expensive, but worth it. I'm also in SoCal and know exactly what you mean about the foggy mornings this week.
