Does my Xeccon Sogn 1100 have programmable modes?- Mtbr.com
Results 1 to 5 of 5
    hey all,
    I have a Sogn 1100. Does this have a driver with programmable brightness like some of my other light heads had? If so, how do I access it?
    The reason I ask is right now, even on "high" the output of the lamp is nothing impressive. It ends up getting washed out by my other bar lamps. My ripoff of a yinding was brighter and had better throw. I was thinking maybe the driver was programmed lower and I could change that.
    Otherwise, I'm quite happy with the light. It's well-made, water resistant, runs for a long time, and came with an excellent stock battery pack, and has a pretty cool removable break-away helmet mount. I just wish its brightness was more along the lines of the advertised lumens, as it wasn't a total cheapo light kit.
    It's a single XM-L emitter, doesn't even advertise as an XM-L2. My guess then is it's probably 700/800 lumens max. So not all that bright by todays standards. I would be very surprised if there was a hidden mode as its not a potent light that could afford to have reduced output modes.
    Reputation: mtbRevolution's Avatar
    Hi 300hp, no the light is not programmable. It's an underdriven XM-L T6 road/commuter light hence the good runtime. It won't perform well as a helmet light due to its shallow reflector. Suggest you try the S12 set for $49 inc standard delivery.
    Leonard - All things Xeccon + Beyond
    mtbRevolution.com
    Leonard,
    Thanks for the reply. Given the run times I've been getting, that makes sense. I might just keep it as-is for commuting and xc skiing at night.....but I still need a good helmet light.
    I'll check out the s-12. Is it available as light head only?
    Thanks again,
    H.
    Sure. $30 for lighthead and 2 o-rings. Standard delivery can take up to 3 weeks.
    mtbRevolution.com
  1. 2016 Xeccon Lights Review: Xeccon Z11
    By tigris99 in forum Lights and Night Riding
    Last Post: 03-14-2019, 11:00 PM
  2. Xeccon Sogn extension cable
    By adriano in forum Lights and Night Riding
    Last Post: 01-07-2015, 08:06 PM
  3. Xeccon sogn 900 dual XML 1300L
    By spankone in forum Lights and Night Riding
    Last Post: 10-05-2013, 10:22 AM
  4. New USB programmable 3A linear driver
    By mattthemuppet in forum Lights DIY - Do It Yourself
    Last Post: 07-09-2013, 11:13 AM
  5. Programmable flashlight on kickstarter
    By BritOnTour in forum Lights and Night Riding
    Last Post: 07-18-2011, 07:10 AM
