Do I need lights with cutoff beam patterns?- Mtbr.com
Results 1 to 37 of 37
    Sep 2015
    Question: How important is light cutoff?
    Hi! I'm new here - just purchased an Airborne Guardian 2.0. It hasn't even shipped yet, but I'm researching lighting options under $100. Most of my riding will be in the evenings after the kids go to bed. I have a couple high output LED flashlights, but I'd like to get dedicated bike lights. I've seen several posts stating that flashlights are a bad option because they blind oncoming traffic, but the highly regarded Nitefighter BT21 & BT40S combo don't seem to have cutoffs (and are likely much brighter than most flashlights).
    Most of my riding will be in my (VERY) dimly light rural neighborhood, with concrete paved streets and walking paths (through heavily wooded areas).
    Reputation: MaximusHQ's Avatar
    I wouldn't worry about cutoff beam on your lights. Just aim the light down a bit at the road and not straight out in front of you. I run the same lights on trail as off, but on the road I'm generally using lower output. Flashlight beams vary greatly so for people to say that flashlights are a bad option isn't accurate. Yes the Nitefighter lights you mentioned are an inexpensive option and seem better quality than the average Chinese lights. I bought the BT40s simply because it was so cheap and they are one of the few offering neutral white options right now. The Bt40s is a bit floody for road riding and more suited to trail IMO, but still it will work. The neutral white beam is what makes the Nitefighter lights desirable right now and if it came in the standard cool beam color most of us probably wouldn't give those lights much thought. Well I guess the battery pack is of decent quality too compared to the typical junk Chinese packs so it has that going for it too, but they are also priced a bit higher than the typical Chinese stuff too. My only concern is waterproofness of the nitefighters, but time will tell on that one as I haven't given it a rain test yet. You are right though the nitefighters don't have a cutoff so they aren't going to be any less offensive to oncoming traffic than the typical flashlight beam other than the neutral tint is less harsh on the eyes.
    Nov 2012
    I believe some countries require lights with cutoffs, such as Germany. We don't have that here in the US. You can aim them a little lower if necessary, or just lower the intensity of the lights if the drivers start getting pissed.
    RAKC
    Reputation: tigris99's Avatar
    if your going to be riding just roads, dont use high powered lights like we do on trails or make sure they at least have lower settings (thankfully most bike lights do), angle them down. The thing of not using "flashlights" isnt a thing of directly angering drivers if used properly, they work just fine on the road as long as your responsible. Flashlights are more of a run time issue but any bike lights are going to piss drivers off if not used correctly. Ones with cut off beams just have a ledge that sticks out over the emitters on top so the cut off does NOTHING unless the light is pointed down like it should be anyway.
    Do I need lights with cutoff beam pattern?
    No....but for the type of riding you mentioned they could be better if the design were right.
    MaximusHQ pretty much nailed it. Aim the lights down and you should be fine. For something like paved commuter paths a lamp like the NF BT21 can work very well when on the lowest level of output. Pointed down and on low ( it is very low ) it works very well and shouldn't blind any on-coming traffic.
    Personally, for the type of riding you suggest I usually use a single emitter LED torch set on one of the low settings. Once again pointed down it is very inoffensive to direct on-comers and still allows me to see what I need to see. On roads ( with no direct head-on traffic ) I'm more inclined to use a regular dedicated bike lamp ( set at an appropriate angle and output ).
    One thing I would like to add is I wouldn't be overly shy about using a bright enough light level to see the road in front of you well. Years ago I would run my lights too dim to see everything in front of me especially with oncoming traffic. I ended up riding right through potholes and whatever garbage littered the side of the road. Luckily on was on my mountain bike and it got me through without crashing. Now I run what ever allows me to see the road clearly even with oncoming traffic. There is more for a cyclist to lose if they hit a big pothole and crash then if some motorist is offended by your light light has to slow down. Sure have consideration for the motorists, but worry about your own safety first.
    Reputation: garrybunk's Avatar
    Feb 2014
    If you want to go with a flashlight, try one with a small reflector/lens size like the highly regarded Convoy S2+ (my EDC is a Convoy S2 neutral white). Smaller reflector means the light is flooder and therefore not concentrated into a motorists eyes. The beam being more floody means it's more even rather than having a really bright hot spot with dim spill.
    -Garry
    Quote Originally Posted by MaximusHQ View Post
    I have to agree 100%. When on the road you use the light in a way that both protects you ( get's you seen ) and lets you see what's in front of you. While you don't want to annoy people personal safety ALWAYS takes a priority. Besides, the way I look at it if you drive a car at night on a regular basis ( like me ) almost every vehicle represents a minor annoyance. Bright lights are "bright lights" and while driving they are all around you. Eventually you get used to the occasional "Superbright" car or truck lamps and learn to deal with it. This is why I never overly criticize someone using a bright bike lamp when on the road. For the most part they are extremely rare and generally not an annoyance factor anyway. Besides it really makes no sense to overly criticize a cyclist using a bright lamp when many motor vehicles are using much brighter lamps that are much more annoying ( and much more common ). The cyclist on the other hand needs to see what's in front of him and just as important, needs to be seen. Being seen helps keep him alive. Bright lights help him/her achieve that goal. If any criticism is to be levied at cyclists it is usually because "They DON'T USE BRIGHT ENOUGH LIGHTS TO GET THEM SEEN".
    I personally have never seen a road cyclist using a lamp that was too bright. On the other hand about 80% of the people I see riding bikes on the road at night are not using lights bright enough to get them ( adequately ) seen or to draw attention beyond a couple hundred feet...and Oh how I wish that wasn't so.
    Last night I saw a guy that was using a very nice set-up ; bright front lamp, bright rear lamp and a couple small wheel lights on each wheel. When you see something like that on the road it is almost impossible NOT to notice them.
    Quote Originally Posted by garrybunk View Post
    -Garry
    Yep, that the Convoy S2 was my newest purchase. Makes a great back-up or commuter lamp.
    Dec 2014
    The thing with a cutoff light beam is that you get the light where you want it. On the road in front of you so you can see the road without blinding traffic. With, let's say BT21, pointing down on low you will see much less of the road and still blind traffic more than for example a Philips Saferide (I know I have both lights and I have done som tests).
    Sep 2015
    Thanks for the responses everyone. I ended up ordering the Cygolight Dash 320 for my bar light. I wanted something bigger/badder/brighter, but I think the Dash will do fine for my type of riding within my sleepy country neighborhood. I'll strap one of my flashlights to my helmet for now. Maybe once I prove to myself (and my wife...) that I can really get into cycling, I'll pony up for something better.
    Quote Originally Posted by Appel View Post
    While I can see some advantage to a cut-off beam pattern for commuter paved paths where there is the possibility of direct on coming traffic, I don't think that such a design is necessarily the best option for road use. On the road you actually want to be seen by traffic that is approaching and you also want to see things in the peripheral that might become a hazard to you cycling at night. From that perspective a "cut-off" beam pattern could be considered counter-productive. Unless we start talking about lamps that emit over 2000 lumen and are in very close proximity to another person I don't think any lamps designed for bike use are going to be a major hazard or annoyance to vehicles that are driving down the road. ( when used properly )
    If you routinely drive at night ( like me ) you see many sources of bright lights that are terribly annoying. There are cars with the new LED/HID lamps, trucks with lamps that are mounted higher, emergency vehicles with high power strobes, road construction crews with lamps designed to mimic daytime conditions, the list is almost endless. Not to mention that almost everyone has had to drive into the sun during sunset at some point. A bright bike lamp pales in comparison to ANY of these things.
    If you're going to criticize a cyclist using a bright bike lamp you need to put all other road factors into the proper perspective in order to give the night cyclist a fair shake. It continues to baffle me that I consistently read ( from other people's posts ) how very bright bike lamps are, "Blinding to road traffic". To me this idea is one of the biggest urban myths I have ever come across. When I drive at night I get blinded almost every night by various vehicles or various sources of bright light. When I say "blinded", I'm talking about the need to either look away from where I'm driving or to adjust my mirrors or to lift my hand to shield my eyes. The only time I've every been blinded by a bike lamp was while mountain biking on trails and I came upon someone else using bright lights ( direct head on traffic that passed me in very close proximity.)
    Lately I've been seeing more people using bright LED bike lights when riding their bikes on the road. This pleases me because the last thing I want to do is run into someone riding a bike at night. The more these people stand out the better and more safer they are going to be. Never, and I mean NEVER have I ever had to either turn my head away or lift my hand to shield my eyes from someone riding a bike with a light that was too bright ( when on a road ). In the future if that ever happens I'll be sure to talk about it.
    Any light with a conical beam if aimed down at one half the angle of the cone apex will put all it's light on the road in front of you in an oval shape.
    For example, my Lupine Wilma has a 26 degree wide beam in a cone shape. If I aim it down at more than 13 degrees, there is little light (spill only) that is going down range that is not eventually hitting the ground. The pattern in front of me is a long oval starting about 5' in front of my front wheel with spill lighting up the area between that and my front wheel/handlebars.
    Aiming a light now by 15 degrees is pretty minimal. No blinding occurs.
    J.
    Dec 2014
    Quote Originally Posted by JohnJ80 View Post
    Yeah, but you get too much light just in front of your wheel. And too little further down the road. And it still blinds. Have you tried look into your Wilma from a distance angled down 15 degrees?
    One big problem is that there is no bright enough light out there with cutoff beam. I've just discovered the potential by using a Philips Saferide. I like the idea to reflect the (little) light there is where you want it instead of just waste a lot of light in a conical beam.
    You dont see the emitters if you look into the saferide. It is just secondary light coming out of the light head, and the reflector puts the light exactly where you want it. It is really effective use of the little light the saferide gives.
    And I don't think it is a good idea to blind on coming traffic to be seen. There are much better ways...
    The germans have understood this with their StVZO standard.
    Please, can't some engineer somewhere construct a decent bike light for road use.
    Depends on the width of the beam but with a 26 degree beam of the Lupine Wilma, aimed as described, it works perfectly. And it is no more blinding that a car headlight is. I typically ride with the lights at about 1500-2000 lumens and go to the full 2400 lumens for high speed descents when there is no opposing traffic. Properly aimed, you have *plenty* of light and it's on target and not blinding. Same is true of car headlights, by the way.
    A properly aimed conical light doesn't waste much light at all. Do the math. If you aim it straight out ahead, yeah - it will waste half the beam. But that's silly, just aim it at slightly more than half the width of the beam down and it's all fine.
    Many already out there.
    J.
    Dec 2014
    J.
    Please, if you can link to some good bike light for road use it would be helpful.
    Gretnabikes.com | Lupine Bike Light Sets
    Piko and Wilma are great. New versions are coming in the next month or so. Bluetooth remote control etc... I have the Wilma from a two years ago that was 2400 lumens max. Current one is 2800 lumens. New one coming is 3200 lumens and has bluetooth control. I typically run mine at about 1500-2000 lumens and then step it up to full bright at 2400 for descending or high speed.
    Piko is 1200 and new one will be 1500. It's a tiny light and also works great on either the helmet or the bars.
    Both of them, I mount them using the GoPro mount under my K-edge computer mount. Really a neat mounting arrangement.
    Road Biking - Light & Motion
    Light and Motion Taz lights are also great. We have the Taz1200 and like it a lot if you want a battery/light in one package.
    I've used both for road riding in pretty much all conditions.
    J.
    Dec 2014
    The lupines are great lights, no questions about that. But I still don't understand how you can recommend a 3200 lumens full beam light only, for road use.
    And can someone tell me why it is such a bad idea to have a bike light with a cutoff beam when you are biking in traffic.
    Dec 2014
    Quote Originally Posted by particle View Post
    Just a comment on the initial post. Would you like cars to drive around in traffic with just fullbeam lights?
    Have you ever tried one? Think about what it's like when you turn on your high beams in a car on a dark rural road. Same thing on a bike and just about the same amount of light. Descending on a road bike on such a road I probably have need for more light than a car because I'm on skinny little tires.
    If you don't think you need that much, then don't buy that much.
    If you aim a conical light down, you get the same effect for all intents and purposes as a "cut off" light.
    Of course not. But I do think it's reasonable to have as much light as a car does. We're both vehicles. A car headlight on low beam is around 1300 lumens, if I recall.
    J.
    I don't think anyone is saying that it is bad to have a cut-off beam pattern. That said I've seen really bad examples of cut-off beam patterns ( on cars ). Earlier this year the company I work for bought some of the newer Ford mini vans. One night I was asked to fill in for someone else and had to use one of the new vans. When I started driving down the road I couldn't believe how bad the headlights were! On low beam the beam pattern went about 60 ft. and then completely cut-off into total darkness. I've driven a lot of vehicles in my line of work and to date these vehicles had the worse headlights I've ever seen. It was so bad that the next day I told my boss that the new vehicles were unfit for night use. While he shrugged off my comment I later found out that the company decided "Not" to buy anymore of the Ford vans. Apparently other employees must have experienced the same issue and had spoken up about it. Like I told my boss, with the extreme cut-off beam pattern I could have a deer standing right in the middle of the road 100 ft in front of me and unless there were some other source of light to illuminate it I wasn't going to be able to see it until I was 60 ft. from it. At highway speeds that wasn't going to work.
    Last night ( out of curiosity ) I took my road torch and held it in front of me ( pointing away, in front of my face ) while standing in front of a mirror ( 5ft. away ). I tilted the torch slightly downward while looking ( directly ) at the light source in the mirror. With the torch set for low I had no problems looking at the light. Set for medium ( ~ 500 lumen ) it was brighter but not blindingly so. At full power yes blinding but I'm standing right in front of the light source and looking directly at the light, something that is not normal in a real world situation. Use common sense and you shouldn't have any problems.
    Also keep in mind that even if you find a lamp with a cut-off beam pattern that ( as a bike lamp ) it is still in the users control as to how the lamp is aimed. A cut-off beam pattern can still be aimed high "if" the user chooses to do so. Of course if they do that they will lose more light directly in front of them, a very bad trade off in my opinion.
    Nope, give me my Gloworm X2 tilted slightly down and set at about 500 lumen and I'm fine for most road situations. The only time I would need more would be for perhaps a high speed down hill run. In that situation I would go to high or turn the helmet lamp on. At least with a helmet lamp you can point the lamp away from on-coming traffic if present. Of course if I'm on a dark road and there are no cars around I can always use as much light as I want.
    Anyway, ( sorry if I ramble on a bit ) I guess what I'm saying is a cut-off beam pattern can work as long as it isn't too confining. I've never used a bike light designed with cut-off but I would think if the design were right it would be very popular with a lot of people. Just remember, just because something seems like it might be a good idea doesn't necessarily mean that it's actually going to be better.
    Dec 2014
    I just see a big potential in reflecting the beam in a more smart way than just throwing it away in a cone.
    I'm still amazed how good the saferide works considering the little amount of light it throws.
    I also have 1,2,3,4 and 7 emitter lights with conical beams that I use when mountain biking. I have experimented quite a lot with elliptical optics on my Gemini Duo and Yindings. Those lights give you more light on the road, yes. But the beampattern is still better with saferide imo.
    It is sad that the saferide have other flaws (bad battery time, bad emitters etc etc) and that philips does not produce the saferide anymore. It would have been interesting to here what you think if you got the opportunity to try one out.
    It is sad that the saferide have other flaws (bad battery time, bad emitters etc etc) and that philips does not produce the saferide anymore. It would have been interesting to hear what you think if you got the opportunity to try one out.
    Yes, it would have. If built today using the better / brighter more efficient emitters the Saferide would undoubtedly be more popular than the original. Sad that Saferide decided to fold rather than to innovate and upgrade the product.
    When the Saferide lamp initially came out I remember thinking at the time that I was not very impressed with any of the videos or beam photos I was seeing. To me it looked too dim and the throw too limited. Not to mention from what I could tell from the beam photos the overall beam pattern was not evenly uniform.
    There are companies that endeavor to design bike lamps that try to control the beam pattern more. Fenix is one. There are also some German lamps that also use the "Cut-off" design but the last I time I read up on those ( yrs ago ) most of those were still somewhat under-powered. Perhaps there are some better offerings now.
    The Chinese on occasion take a stab at trying to create a commuter bike light. While most of those tend to look very funky "This One" shows some promise. If you read the product description apparently the lamp is designed with a cut-off beam pattern. Funny because the Chinese didn't really know what to call it so they describe it as such...
    ( Kaidomain ad ) >...The NEXTORCH® B10 is a perfect light for riding, urban city and around-town commuting. It features patented RSL™ technology to provide a unique rectangular spot, delivering a 160 degree wide beam and whole-road lighting for greater visibility to guarantee rider’s comfort and safety. The anti-glare design allows distinguishing the areas to be lit and those to be left dark, illuminating the road without disturbing pedestrians. The B10 has 4 modes, max output up to 400 lumens powered by 4 AA batteries. A low battery indicator keeps you from getting caught in the dark. The tool-free FlexStrap mount bracket that allows you to quickly and easily attach the B10 to virtually any handlebar.
    ...it would be interesting to see one of these in person. The ad beam photos look promising but alas it is best not to trust the manufacturer's ad photos. Sooner or later someone will buy one and review it. At least the price is right. If it has decent throw and an evenly dispersed beam pattern one of these might fit the bill for someone looking to buy a self-contained bar lamp for commuting and or paved bike commuting paths.
    Reputation: MRMOLE's Avatar
    http://forums.mtbr.com/lights-diy-do...-a-800662.html
    I thought you might find this interesting. It predates your MTBR join date so I'm guessing you haven't seen it yet. Also I too like elliptical optics and was wondering what types you've used in your Yinding/Duo?
    Mole
    I believe that Garmin even changes the beam shaping based on speed. The light is pretty wimpy in terms of lumens but the idea is there.
    Beam shaping is probably the next big thing in bike lights. We're sort of at the end of the lumens wars so it is really the last major feature category on which to innovate.
    I think it would be great if there were a smartphone app that allowed me to configure the parameters of my light - color, beam shape, brightness settings, etc.. Lupine is sort of touching on this now (my understanding) with their BT connected lights. That's a lot better than remembering some arcane button pressing UI that most lights currently use.
    I tend to prefer the conical shaped lights. The way I aim them, I like the beam pattern they leave on the road for me. I'd like to be able to select that or change it for the application that best suits the riding I'm doing.
    J.
    Discussion on bike lamp cut-off beam patterns
    ...I tend to prefer the conical shaped lights. The way I aim them, I like the beam pattern they leave on the road for me. I'd like to be able to select that or change it for the application that best suits the riding I'm doing.
    J.
    I have no real issues with conical shaped beam patterns but I much prefer the use of optics which usually can give a more evenly dispersed beam pattern.
    In keeping with the discussion on " cut-off " beam patterns I just now did some testing with my usual bar mounted torches that I use when on commuter paved paths and this is what I discovered;
    First , what I did; I mounted my bar torch to my bike and aimed it slightly down like I usually do. ( this test being done inside my home ). The bike was roughly 15 ft. ( 4.6m ) from my living room wall. I then stood in front of the wall to make some observations. While doing this I discovered a couple of interesting facts.
    For one, my normal angle of downward tilt ( ~ 25° ) was not enough. When I preceded to modify the angle I discovered quite by accident that I could see the "conical cut-off" of the torch being projected on my living room wall. That turned out to be quite useful. I also discovered ( but already assumed ) that not all torch reflectors have the same spill diameter. A more narrow spill pattern turns to be more useful because you don't have to tilt it down as far. This means more light is aimed further out without shining directly into any approaching pedestrian traffic's eyesight.
    I also discovered that if you do this kind of test in complete darkness it makes a lot of difference. Once your eyesight is accustomed to total darkness any "direct" on-coming source of light can be very blinding if it is not attenuated properly. I should note though that if you are more than 5 ft. or so off to one side the discomfort level is not as pronounced. The danger area is "any person directly in front of the bike". The closer they get the more the discomfort.
    After my initial test I then aimed the torches more downward ( ~ 45° or more depending on the spill of the torch ). With the wall as my guide I made sure the cut-off was below my head level. This made a pronounced difference in how comfortable it was to view the lamp from the front, even with outputs up to 500 lumen. Of course at a 45° downward tilt you won't be able to see as far so this means you need to slow and pay more attention to your visible line of sight.
    With these things in mind I have developed a new personal strategy for paved bike/commuter paths; I'm going to ride with my back-up bar torch on low and aim it 45° downward. My main lamp ( Gloworm X2 ) I aim as normal ( very slightly down ) and use as before. The idea being when I see approaching traffic I just turn the GW off. This of course assumes I have a far reaching POV and have time to power down the main lamp once I see approaching traffic. I just have to keep in mind that on some paved trails I don't get to do that because of the shorter viewing distances. Not to mention that on some paved trails there are sections that I come up on approaching traffic without much warning. People running and cycling can at times seem to come out of nowhere.
    The last time I rode on a paved path system at night I know I blinded a couple people ( by accident ) for that very reason ( short lines of sight ) Next time I go out I'll have a much better strategy in place.
    Of course like I said before, all of this pertains to "Traffic approaching directly from the front" when on narrow paved paths. If you ride on a roadway with a normal shoulder area you can be much more liberal with the adjustments of your lamp. Just remember, 5-6 ft. off to the side makes a BIG difference when it comes to glare factor. Just keep in mind all the off setting factors in how you use your lamps....total output, projection angle and lastly off-set angle and off-set distance of approaching traffic make a huge difference. With all this said when it comes to road use, "Use the amount of light you need to protect yourself from road hazards". Your safety is more important than the minor annoyance of a motorist.
    Dec 2014
    Quote Originally Posted by MRMOLE View Post
    Mole
    I was already aware of that thread. Thanks anyway.
    About elliptical lenses. I have the 20*60 and 30*60 from leddna. They are a little bit too wide imo. The 10*45 might be better, but I have not tested that one.
    LEDDNA - Search Results for "Elliptical"
    RAKC
    The 10x45 is narrower laterally but the beam beams a thin strip of light. Something more towards 20x45 would be good for that purpose but not sure they even make an optic that will do it. I know leddna doesn't, not sure beyond that.
    Dec 2014
    Fenix has som kind of lens that looks interesting. But I don't think one can buy them separately...
    Fenixlight Limited
    I've got the same Leddna optics and agree, too wide. For the Duo/Yinding it also created too large of a coverage area and because of their power limitations kills the intensity levels more than I'm willing to accept. I've been using Gloworm "XS ellipticals". They behave more like a traditional wide angle lens and if I had to guess at lens angle #'s I would say 20*10 or maybe 20*15. Light intensity levels don't drop too much and they retain a good amount of throw but for emulating a cut off beam they don't work too well. Best I've used for this purpose is Actions "wide angle lens" for MS808/Gemini Titan/clones. Too bad they don't work as well with smaller lens/optic diameters.
    Mole
    Dec 2014
    And the elliptical lenses also "cutoff" the beam both on top and on the bottom of the beam. So you loose light in front of your wheel. You only want to cutoff the top of the beam.
    May 2005
    I have long wanted a reflector from the Saferide to build a cut-off beam light with.
    Spent a fair bit of time testing parabolic reflectors cut in half, trying to duplicate the Saferide. Not an easy job. None worked well enough to warrant building with.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    RAKC
    Still buy them on amazon . $140 though
    As for the fenix lens, its a one piece optics specifically made to fit fenix dual light heads. And its not a cut off (the over hanging lip of the casing does that job, just not great at it) its basically like an elliptical spot rotated 90deg, so you have a strip of light I. A line from the front tire out to the main spot. But the lip cuts it off so it doesn't continue upwards into eyes of on coming traffic.
    NightRider
    Reputation: gipsyman's Avatar
    Nov 2014
    I haven't seen anybody mentioning the Specialized Flux Expert bike light. Do a Google search and you will see reviews along with Youtube videos. It uses 3 XP-G2 leds. The manufacturer rates the cut-off beam pattern at 800 lumens. It has a high beam setting that doesn't cut off completely of 1200 lumens. For 2 years, I have used a modified Philips SafeRide that is extremely efficient and has great throw (15000 lux on high) but being a flashaholic, more is always better to have available. The only time I wanted more light in the last 4000 miles of street riding with my SafeRide was on newly paved real black asphalt.
    May 2005
    Quote Originally Posted by tigris99 View Post
    Just a bit much for a reflector!
    Quote Originally Posted by gipsyman View Post
    ( ^^..Specialized Flux Expert ) < Well there you go. A high powered bike light designed to have cut-off. Includes a remote too, good show. I like the mounting solution as well.
    Would be interesting to see some better beam photos. All of the videos sucked ( as can be expected ). Not cheap, $275 is a lot of money but I suppose if you are die-hard into cut-off beam pattern you might be willing to throw down the coin. Looks like a nice set-up. I'd love to see one in person if just to see if the cut-off really works and whether it is really bright enough for the serious cyclist.
    .... Never, and I mean NEVER have I ever had to either turn my head away or lift my hand to shield my eyes from someone riding a bike with a light that was too bright ( when on a road ). In the future if that ever happens I'll be sure to talk about it.
    ...and so I shall. It happened just last night. I was driving in an urban environment with lots of stores and streets lights. Low and behold as I'm driving down a multi lane parkway off to my right ( on the sidewalk ) I see a very, very bright light pointing in my direction. Riding against traffic ( a big no, no but on a sidewalk ) was a guy who looked to have three very bright LED lamps mounted ( in a pyramid ) to his bars. ( yes, it was very odd )
    I was indeed blinded for a moment till the angle of my approaching vehicle changed enough to off set his lamp. Yeah, first time for everything but how many people are going to mount three bright LED lamps to their bars and then ride "toward approaching traffic on the wrong side of the road"? The whole incident was very odd.
    I had a similar incident today: I was approaching a traffic light where I was going to make a right turn. Before I made my turn I could see a good quarter mile up the highway what appeared to be a very bright flashing white light. Once again, someone riding "Against traffic" I assume. I wasn't close enough to be blinded but no doubt if I had continued straight ahead I would of been for a brief second.
    So...with all this in mind...I change my previous statement to; "I've never been blinded by anyone using a bright bike light correctly"....
    I will grant that aiming on LED lights is more important than with incandescent or halogen lights. But once that is done, then it shouldnt be a problem. I'd guess that these lights were also aimed improperly?
  1. Mini Review + Beam shots: Xeccon VS other Chinese lights
    By Rocky Raccoon in forum Lights and Night Riding
    Last Post: 02-08-2014, 03:13 AM
  2. What is your cutoff temp?
    By TenSpeed in forum Commuting
    Last Post: 12-14-2013, 04:43 PM
  3. What is the cutoff for a clyd?
    By Dung Hopper in forum Clydesdales/Tall Riders
    Last Post: 08-27-2013, 11:04 AM
  4. Niwot ridge/cutoff trail
    By bpk013 in forum Colorado - Front Range
    Last Post: 09-05-2011, 08:35 AM
  5. 1995 Ritchey Lite Beam Softride Beam bike
    By First Flight in forum Vintage, Retro, Classic
    Last Post: 06-15-2011, 11:05 AM
