DIY diffuser ?- Mtbr.com
Results 1 to 7 of 7
Thread: DIY diffuser ?
    Apr 2005
    DIY diffuser ?
    does anyone use DIY diffuser material for flashlight?
    May 2005
    Personally no, but on the DIY forum there were threads where folks experimented with different things. Satin finish Scotch tape was pretty popular on an optic face or reflector cover. Others had luck coating the glass over a reflector with satin clear coat spray.
    Some even sprayed the reflector itself. IIRC there was something used on or near the nozzle to make the spray splatter so that the finish was sort of textured.
    Might be worth some time spent searching that forum for those old threads.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Reputation: MRMOLE's Avatar
    I've used the "Action-LED-Lights" wide angle lens cover on several lights it was not designed for (like this C&B Seen 3up) with good results.
    Mole
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ an array of parallel cylindrical lenses or prisms will refract light perpendicular to their long axes while not spreading it along their long axes. This is can be helpful on a light with a narrow circular beam.
    Do the math.
    Reputation: znomit's Avatar
    Glad Press'n'seal works well.
    Well, for my working headlight I've just made circular cut out of matt plastic cover from some box (folder) and put it over the lenses. It also made light more neutral white. Of course I lost about 20-30% lumens OTF, but light is nice evenly spreaded. I'm using it daily.
    You can also get a lifetime supply for under $15 by going to the hardware store and picking up a florescent light panel that helps to defuse light.
  1. DIY Diffuser?
    By mwalker411 in forum Lights DIY - Do It Yourself
    Last Post: 11-20-2018, 07:39 AM
  2. Betty R with Diffuser (Bar Mount)
    By stu06 in forum Lights and Night Riding
    Last Post: 12-19-2014, 08:49 PM
  3. Flip down diffuser
    By DIYtailight in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2011, 07:56 PM
  4. What DIY voltage regulator for DIY lights
    By dmalovic in forum Lights DIY - Do It Yourself
    Last Post: 11-29-2005, 11:17 AM
  5. Replies: 18
    Last Post: 10-14-2005, 11:50 AM
Members who have read this thread: 37
