DIY 2 Cell Helmet Battery- Mtbr.com
Results 1 to 7 of 7
    Reputation: gravitykid's Avatar
    I'm after a two cell battery for to mount on my helmet for my BT21 and I was thinking of making my own.
    I was looking at using one of these holders for 2 x 18650 cells.
    Fasttech Link here
    The holder comes with a protection circuit and I was then going to load it up with two unprotected Panasonic cells, fit a length of cable then heat shrink it.
    A few questions:
    - Does what I'm planning to do make sense?
    - Is there anything that I should be cautious of?
    - Where can I get a decent 20awg lead from (I've got 22awg)?
    - The description says 7.4V but the battery on my light is 8.4V, is this an issue or will I get 8.4V in reality?
    Reputation: ljracer's Avatar
    Quote Originally Posted by gravitykid View Post
    Fasttech Link here
    A few questions:
    it will work fine. I did that for a while. However I still use an extension and put in my jersey pocket.
    I use the DX magic shine extensions or y cables to get thicker wires.
    the cells are 3.7 volts (4.2 on full charge) to you get 7.4V. It ends up getting to 8.4 on full charge. for a 2SXP configuration.
    I would shrink wrap and plastidip the ends to water proof.
    I went to building soldered 2 cell packs as they are a little smaller and neater.
    Here you can see the finished pack for your plan. And then vs 2 cell soldered pack. With your option you can always pull cells out to charge them for balancing occasionally.
    Quote Originally Posted by ljracer View Post
    Thanks, that's great information.
    Looking at your photo I definitely want to go down the soldered route, it's a much neater solution.
    Where do you get your protection circuits from? I've seen some on AliExpress and eBay that look similar to the ones in your picture.
    Feb 2015
    Look here: http://forums.mtbr.com/lights-night-...gb-982688.html
    Some people built packs using protection modules from "hunk lee" on ebay.
    Reputation: patski's Avatar
    Dec 2005
    Quote Originally Posted by nathan89 View Post
    I get 2 hrs on my Gloworm X2 with a HunkLee 2 cell in a magicshine velcro case. Dipped the 2cell in Plastidip to make it waterproof. Performix 12213 Plasti Dip Black
    Post pics of your helmet/light setup.- Mtbr.com
    I got my pcbs from Hunk_lee on ebay. His store is fma battery.
    Right now gearbest has ncr18650b for 4.24 each.
    I picked up nickel strips off ebay for connections. Search the threads here for technique if you want to make your own.
  1. C&B Seen upgradable 2 cell Helmet battery Case Review
    By Skyraider59 in forum Lights and Night Riding
    Last Post: 11-09-2017, 03:04 AM
  2. Gemini 6 cell battery with a gloworm xs.
    By mazspeed in forum Lights and Night Riding
    Last Post: 09-17-2014, 10:37 AM
  3. Building a four cell battery pack. How to charge it?
    By roxtar in forum Lights DIY - Do It Yourself
    Last Post: 12-05-2012, 12:04 PM
  4. Battery life with Gemini Olympia 4 cell
    By gabby1 in forum Lights and Night Riding
    Last Post: 11-19-2012, 02:55 PM
  5. pre-made battery pack vs. battery cell holders
    By Andy13 in forum Lights DIY - Do It Yourself
    Last Post: 01-28-2011, 11:58 AM
