Bontrager Flare RT mode confusion- Mtbr.com
Results 1 to 43 of 43
    Feb 2019
    Does anyone else use the Bontrager Flare RT rear light? I searched the forum and didnt have much luck finding any threads. Apologies if I missed a thread.
    I have a hard time telling the difference between all the modes. I called American Cycle and Fitness (Trek dealer around me) and they said all the modes listed in the manual for this will be "in order from top to bottom as listed in the manual" but thats not true at all in my Flare RT at least..
    There are 5 different modes in the manual
    Day Flash: 90 lumens for 6 hour runtime
    All Day Flash: 45 lumens for 12 hours
    Night Flash: 5 lumens for 15 hours
    Day Steady: 25 lumens for 4.5 hours
    Night Steady: 5 lumens for 13.5 hours
    I just want to use the Day Flash 90 lumen mode and/or All Day Flash depending on what kind of riding I will be doing (Day Flash for shorter commutes and All Day Flash 45 lumen for my longer rides).
    Problem is...... I cant tell what mode is what. They all look the same with the exception of the Steady modes.
    Also last night I tried a long press and hold for 15 or so seconds like on the Ion Pro RT 1300 headlight and it blinked red once.
    When I turned the RT back on, it was just im guessing the full 90 lumens blinking WITHOUT the ambient auto brightness adjustment or something like that.
    It looked like kinda strobe mode like in some of the LED flashlights/torches that you usually have to cycle through (except it was just the normal tail light flash lighting up the entire room at 11:30PM.
    Can anyone help me figure this thing out?
    Example.... On my RT the "Steady" modes are both at the bottom.
    Day Steady then Night Steady.
    When I enter one of the Steady modes, it is not followed by the night Steady.
    It instead cycles through 2 more Flash modes then another Steady mode.
    I am so confused with this thing.
    The ACF man I spoke with also said that "double clicking the button will lock the light into that current mode" I have it in.
    Wrong... It does the same thing the Ion Pro 1300 does... Just a really quick cycle through the modes.
    Anyone have any idea what that 15 second press thing is?
    I am thinking that is the Day Flash at the 90 lumens, but the man pretty much insisted that I was crazy just without actually saying I am crazy.
    Thanks,
    Mike
    Jul 2017
    Hi
    You confused me with your post
    I cant remeber clearly but there are three long press adjustments. One of them turns on/off the bluetooth , one locks the light in the light setting its currently in and the other long press turns off the ambient light sensor.
    The manual that is inside the box will tell you wich does what. I dont have the manual anymore so i cant help with that.
    The light modes on my (new model) flare rt are in this order.
    90 lumen day flash - 45 lumen all day flash - 5 lumen night flash - 25 lumen day steady - 5 lumen night steady. The last two modes are both steady. If you cycle trough the light modes , the first flashing mode after the two steady ones is the 90 lumen one. After that its the 45 lumen flash.
    Its indeed very difficult to distinguis the 90 and 45 lumen day flash. I think thats because the 45 lumen flash is also very bright.
    Feb 2019
    Hi and sorry for confusion. I got my Flare RT August 2018 so idk if it's the new one or not.
    My last two modes aren't both steady. I got into a steady mode then pressed the button once for the blinky mode. It occasionally flashes a lot brighter then normal. Idk if that's normal or if that means it's the 90 mode.
    I haven't noticed the second blinky mode doing the occasional bright flash yet.
    These steady modes aren't like you say in mine.
    I got it in the ion pro 1300 rt kit.
    Sorry i just have no ideas whats with this thing. Could it be the old flare rt purchased August 2018?
    Jul 2017
    Have you disabled the ambient sensor ? If not i would try that first. It ships with the ambient sensor enabled. If you are in a dark room or outside and there is not much light outside and you turn on the flare rt and switch light modes it automaticly turns from day flash to night flash or from day steady to night steady. It wil blink bright for a few seconds and then it gets dimmer to the night setting.
    If that doesnt fix it i dont know what will.
    The ďnewĒ flare model is the 90 lumen version that looks like a cube. The older model is also called the flare rt but is round at the bottom and is 65 lumens in the brightest setting.
    Feb 2019
    I haven't disabled ambient light sensor. I have the 90 lumen.
    Thanks Dennis that worked! Now the modes are not all weird.
    When i turn the light off will it come back on the same mode next time i turn it on? If i don't use the lock
    Jul 2017
    Okay nice
    Yes the flare rt remembers the setting it was in before you turned it off and thats again the setting its in when you turn it back on.
    Feb 2019
    Thank you you're the best!
    Jul 2017
    I was also very confused when i bought my first flare r with the ambient sensor. Before that one i had a first gen old model flare r and after a year i bought another old model flare r but Bontrager added the sensor in the exact same model and i didnt know that. I thought it was broken out of the box
    Feb 2019
    I'm not too crazy about the ambient light sensor thing if I'm being honest at least when I'm riding city.
    I want it to stay in whatever mode i put it on.
    So thank you. I had a massive brain fart and didnt even look on the other side of the manual cuz i figured it would be Chinese like almost everything else made.
    Kinda confusing why when the ambient mode is on, the modes aren't in the order the manual says.
    Was yours like that? Only one steady mode then switched to 2 more blinky modes before it went steady again?
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yeah. I checked the light level on mine sitting on the side of the road in the shade of a tree on a bright sunny day and it was in night flash...not what you want when you're riding along the side of a road on a sunny day and happen to be in the shade. I disabled the light sensor.
    Do the math.
    Feb 2019
    Exactly! Does your light shine on your rear tire a bit? Mine does but not too much. I'm a shorter guy. Only 5'6".
    I can't think of anywhere else to put it unless that's just like the spill from all different kinds of flashlights and headlights
    Jul 2017
    If you have a Fizik saddle than there are 3D printed mounts for the Bontrager Flare rt lights that click on the back of the saddle. Shapeways.com sells those.
    You can even get a Fizik saddle custom made in different colors so it matches your frame.
    Thats what im gonna buy for my bike. The silicone strip doesnt look so nice on my seatpost but its a fast way to get the mount on/off the seatpost.
    You could also buy a different seatpost mount for the Flare rt from Bontrager itself. Your dealer can order those for you. They are a couple of dollars. Look at the Trek site by the lights they sell. The hard mount screws on your seatpost and the angle of the light is adjustible.
    Jul 2017
    With the Bontrager mount you can also take it apart and mount it like this.
    If you take the plastic piece out of the silicone strap you could mount a ion 200 front light on the fork if there is a hole on this place. But then its only usable as a day time light because it points slightly upwards and it doesnt light up the road in the dark. But stil very very visible in daytime. And it looks sleek
    Hope this gives you some mounting ideas
    Feb 2019
    I have a "SELLE ROYAL" "SR" Saddle. The "COOLXSENIUM"
    That i bought from American Cycle and Fitness Trek dealer here.
    Is that mount like sorta a Blendr type?
    Jul 2017
    The Fizik mount only works on Fizik saddles.
    (This is weird , i placed a link below in this post but its invisible on my phone but when i click on my post it does work)
    https://www.shapeways.com/marketplac...er&sort=newest
    Feb 2019
    The link works on my iPad. Thanks for the help I appreciate it.
    Feb 2019
    So what mount would I need to mount the flare rt up under my seat like in those pictures? Dennis1987
    Jul 2017
    This one
    https://www.trekbikes.com/nl/nl_NL/f...olorCode=black
    In my case the lights angle is a bit downward. Look at the angle of your seatpost screw and check if its not too much at an angle. In the dark it will light up the road like crazy behind your bike but at daytime it makes the light a bit less bright if it angles a bit downwards.
    I did it like this. I removed the seatpost screw wich connects the upper part of the seatpost with the seatpost. This screw is a litlle bigger than the hole in the Bontrager mount. I screwed the seatpost screw with a imbus tool in the mount. This leaves you with screw-dread inside the mount. Then assembled the seatpost again and so that the bolt screws also in the mount.
    It is very sturdy.
    I find it looks nice and sleek
    Allso the mount is nearly invisible if you take the light of
    Feb 2019
    Quote Originally Posted by Dennis1987 View Post
    This one
    It is very sturdy.
    What's the pay called?
    It took me to the website with a language I don't understand and yes that does look pretty sleek and cool
    Jul 2017
    Oh yeah that was Dutch
    Bontrager Flare Round Mounting Kit
    https://www.trekbikes.com/us/en_US/e...olorCode=black
    Feb 2019
    Lol thanks m8!
    Heres my bike with the included mount... see how much it shines on the rear tire?
    its not letting me upload the pic with the tire. Says it failed to upload....
    and how do i upload these phone pictures so they wont always be sideways?
    Feb 2019
    but a picture of a simple flashlight from same phone works perfectly fine..
    Jul 2017
    I upload them to pinkbike and then post the link here.
    I see you have a different model seatpost. How i did it doesnt work with yours. The rear bolt is far too upwards.
    But you could still use the round mount kit and just clamp it to the seatpost the normal way.
    Feb 2019
    just with the rubber piece that came with the flare rt?
    I just have the Trek Marlin 7. I think im confusing myself and maybe others.... sorry.
    when you say seatpost, are you referring to just the round seatpost or up in the bottom of the seat where the bolt is?
    Jul 2017
    Just on the seatpost like you have the silicone mount , not under the saddle. I like the Flare Round Mounting Kit more than the silicone mount. Its rock solid , doesnt shift sideways and the angle is adjustable.
    The silicone mount always triggers my ocd because i want my light 100% straight and not a little bit to the left or right
    Feb 2019
    how about if i put the seat that came with bike back on, would that work?
    and also, that pink bike website i put some pictures in there but idk how or what link to copy and put in this forum. Sorry guys, im still pretty new to this forum.
    and Dennis1987 do you know why my phone pictures the are taken in the horizontal mode are always showing up on here sideways?
    Feb 2019
    ok so horizontal pictures are the way to go. anyway see how much red is on the tire? I dont think thats too good but i could be wroong again
    Feb 2019
    Quote Originally Posted by Mike2288 View Post
    Ok i am the worlds biggest idiot....... i was mounting my flare upside down. I dont need a mount lol.
    Feb 2019
    Thank you SO much for this thread! I bought my Flare RT in December. I noticed that it had those 5 different modes listed in the Manual (and some online videos that I read), but I tried to 'cycle' through the modes, and I couldn't tell the difference between ANY of them! I thought it was just me (or maybe I had a defective unit). But I guess its on the Ambient sensor still?
    Also, on the Manual, it states that you do a 'double click'. However, for me, it only works with one click (I don't even get to the double click before it switches on). Anyone else have this issue...?
    Jul 2017
    The double click to turn the light on only works on the ion 1300.
    The ion 1300 only turns on after a double click. All other lights (ion 200/800 and the flares turn on with one click.
    Feb 2019
    Wrong info
    Edit: Dennis is right. I got confused (watching Netflix while reading and typing at same time and I suck lol).
    Feb 2019
    Ok umm ion 1300 is double click on. Flare rt single click on. Donít mind my craziness. Sorry
    Feb 2019
    I am so glad I found this thread!
    I was double clicking....and it wasn't working, and I was trying to cycle through the 5 modes, and they ALL looked the same to me!!
    Thanks folks for clarifying all of this!
    So, do you think I could leave the Ambient sensor on (and let it adjust the light automatically) or do it manually?
    Feb 2019
    Quote Originally Posted by RiltonHuggles View Post
    I prefer doing it manually but thatís just me. If youíre riding in the shade it might switch to night mode like one of the people in this thread said happened to him.
    I want to be seen. Thatís why I bought the kit. Idk if it really is 2 kilometers but it is pretty dang far. I say go manual if safety is high on your list like it is on my list
    Flare RT; spotted
    Today while on my way to the store I spotted a guy ( in full daylight ) using what I think was the Flare RT on back of his Trek bike. I have to say I was very impressed. The guy was sitting at a light and I was probably about a good 500 or more feet behind when I first saw the light. I saw the light first, then the cyclist. He was still at the light when I was able to come parallel at the light. The configuration of the lamp looked very much what the Flare looks like online in the photos.
    I'm still not one to use my rear lights during the day but it's nice to see that they do work provided you use the right light.
    Feb 2019
    I've been blasted by both the front ion pro light and the flare rt from a few hundred feet away. Ion pro i was walking and yeah that definitely gets your attention during the day. I'm impressed how well this day flash works (it was a friend of mine that has this kit also).
    Tail light like Cat said. For sure you got to use it right and then it's great.
    Maybe that's why all the drivers honk at me from behind. That or they're just being very rude for no reason (calling me names i can't say on here).
    I swear i thought i was gonna have a heart attack and I'm only 31.
    Drivers dont follow the laws for bicyclists at all here in Chesterfield Michigan.
    No sidewalks or bike paths for main road rides. Riding over knee size rocks and 2 foot tall grass uphill gets very hot and tiring. Sweat in the eyes burns lol.
    But yeah anyway.... glad i purchased this light kit. I bring my charger with me everywhere in a ziplock bag in case of downpour.
    Drivers dont follow the laws for bicyclists at all here in Chesterfield Michigan....
    Never assume the reason why someone does something stupid. That fact that they did something dumb or stupid is all you need to know. Someone who would blare their horn at you ( for no good particular reason ) or yell at you out a window just means that it's someone who thinks the world revolves around themselves or otherwise just has an obnoxious personality. Lot of people like that nowadays. Best to just ignore them if possible.
    Feb 2019
    I always ignore. I don't name call or shout. People are dumb. It just scares the crap out of me sometimes. Mostly from behind with the horns
    Feb 2019
    Does anyone know how to attach the Bontrager Flare RT to a seatbag?
    I have the strap that came with it that attaches to the seatpost, which I have been using since I purchased it. But I have since bought a seatpost bag and there isn't enough room for my bag and strap for the light on the post. But my seatpost bag has a great strap to attach a light and I was hoping to do it that way...
    Thoughts/suggestions?
    Jul 2017
    Dec 2013
    ^^^ one caveat. These lights are best when aimed correctly. Attaching to a bag or backpack strap often lets them angle downward or to the side which can greatly reduce effectiveness. For best performance try to ensure they're aimed correctly.
    Do the math.
    Feb 2019
    Cool! Thanks!
    Feb 2019
    Quote Originally Posted by Lone Rager View Post
    Good point!
  1. Shred Dogg Gravity Mode vs Megatrail Trail Mode
    By stripes in forum Guerrilla Gravity
    Last Post: 12-03-2018, 04:40 PM
  2. Replies: 12
    Last Post: 11-01-2016, 07:15 PM
  3. Bontrager flare r
    By JUNGLEKID5 in forum Commuting
    Last Post: 06-08-2015, 08:37 PM
  4. giant reign float shock climb mode feels same as descend mode
    By mobilenemo in forum Shocks and Suspension
    Last Post: 03-21-2014, 03:26 PM
  5. OT: Hybrid mode vs. Linear mode
    By Davis61381 in forum Site Feedback/Issues
    Last Post: 08-28-2006, 07:45 AM
Members who have read this thread: 33
