Best Helmet Mount for Under $50- Mtbr.com
Results 1 to 5 of 5
    Reputation: OneEyeMan's Avatar
    Aug 2005
    As the title says, I'm looking for the best helmet mount light for less than $50. I don't need tons of bells and whistles. Just low and high, 2.5 hrs run time, light, reliable, easy to mount. Self contained battery is desired, but not necessary. I already have a Light and Motion HID handlebar mount light with a wide pattern so I'm just looking for a tight beam for the helmet. I just don't have the time to search every light article on this site so please refrain from the "search is your friend" type of responses. Links and pix are a bonus.
    Thanks all,
    Lenny
    Yinding is still good for the price. Lightweight and selfcontained doesn't go together, so no way to get 2.5h unless you change the cells or run on low.
    Reputation: MRMOLE's Avatar
    While self-contained lights have improved considerable they're still not the best choice for helmet use. Only ones I know of that will run for 2.5+ hours on high are the Ravemen PR900, Gloworm CX 900/1300, and Ituo WIZ 1, none of which cost less than $50. If your starting from scratch even the Yinding + battery + charger + helmet mount will be over the $50 mark as will the Magicshine 808 L2 once you add the helmet mount although close.
    Mole
    https://www.action-led-lights.com/co...ode-bike-light
    Aug 2005
    Thanks for the replies guys.
    Don't get too hung up on "self-contained"
    If they're not available at that price point, don't worry about it.
    2.5H run time could mean lots of different things. You need 2.5H of run time on the brightest setting? I only need to use the "high" mode for fast descents, and a ride with 2.5H of descending would be a VERY long ride. I can't give good reccs on current models, but I would guess many torches work on the helmet and would get you through a 2.5H ride that maybe had 20-30 minutes of high and the rest on low. Lightweight and selfcontained! Throw in an extra battery in your pack and be safe.
  1. Replies: 1
    Last Post: 12-03-2015, 11:36 AM
  2. Tripod mount Contour Roam 2 onto Magicshine helmet mount?
    By khaytsus in forum Videos and POV Cameras
    Last Post: 07-31-2013, 06:35 PM
  3. Custom helmet mount for magicshine mj-880 using go pro mount
    By awareham83 in forum Lights DIY - Do It Yourself
    Last Post: 12-27-2012, 05:13 PM
  4. One light - bar mount or helmet mount?
    By BarryGXNZ in forum Lights and Night Riding
    Last Post: 11-05-2012, 04:26 PM
  5. Best helmet under $100?
    By kawi46 in forum Apparel and Protection
    Last Post: 05-23-2012, 06:36 PM
