Baja Designs Question?- Mtbr.com
Results 1 to 8 of 8
    Ok just pulled the trigger on a Double Strykr....read up on them from here...on sale $350, pretty good deal on the light..Now my budget was $550 and I would like to also purchase the Strykr Sl for my helmet...Baja Desings has them on sale now for $250...$50 bucks over for me...So I am looking on eBay and I see some listed....SO HERE IS MY QUESTION....how can one tell the difference between the old stryker pro and the new strykr SL ... I know the Sl is the improved version, more light output...but the housings look the same...I'm looking at pictues on eBay, so I cant just turn the light on. I have dealt with some junk on eBay before and returned...item not as described...some Strykr SL listed as new, but how can one tell...optics, emmiter? Shannon could use some help here...Thanks
    Reputation: Baja Designs's Avatar
    Aug 2010
    Hi Pedaldown, in a huge bit of irony I am at a 24hr race here in California as I write this, hawkin' Strykr series lights as we speak. The quickest way to differentiate a Strykr Pro from an SL is that the bezel on the front of the SL is gray instead of the black on the Pro. If there is a good enough picture of the system you'll be able to see the Pro uses a thick TIR style reflector (solid) whereas the SL uses a more standard reflector inside a lens
    Hopefully that helps, let me know if you have any other questions. Congrats on your Double Stryk, welcome to the Baja Designs Nation!
    Thanks for the info...Shannon
    Aug 2010
    Quote Originally Posted by pedaldown View Post
    You are welcome. Did you find the Strykr SL of your dreams yet?
    The double Strykr will be here Thursday Sept. 6 and the the Strykr SL is yet to be shipped, Would have been nice to just order both from Baja Designs for $550.00 combo package... Amazon someting like $337 plus $5.00 shipping, so the double Strykr ended up at $342.00 The Strykr SL New on ebay, winning bid of $208.00...well $545 for the combo. We ride at Fort Custer in Battle Creek Michigan at 6:30pm, so not quite dark yet at the start of the ride, close at the end, about 16 miles...Do they still have a contest going on..I have a gopro Hero 2, I could do some night ride video.
    Aug 2010
    Hey Pedaldown, we do still have the video contest going on. It'd be great to see what you can do! I look forward to seeing some that gnarly riding you guys have out there in Michigan.
    Shannon
    Sep 2012
    I'm really thinking about getting the Strykr's, have you tried it out, yet and did you find the SL? I would love to see some trail shots to see the light output.
    Double Strykr and Strykr Sl review
    Quote Originally Posted by cr500taco View Post
    The Double Strykr AWESOME...just to give you an idea, turn on your bright car headlights on a dark road and now at least double the distance you can see ahead, that would be with the Double Strykr . I did this with a Chevy truck in a field. Chevy truck a good 75 yards, the double strykr 150 yards awesome, plus I could see the far tree line at 450 yards, lightly, but you could tell what was coming into view well in advance. The Double Strykr handle bar mount, very nice, centers over the stem, easy to adjust up and down, left or right, the light is mounted very secure, no movement over the roots and rocks and jumps, Will say could use a clip to secure the light pig tail when mounted to the bar when the pig tail in not connected to the battery and a rubber boot to go over the pig tail connection when not in use, and a nice Baja Designs lens cover to go over the double strykr lens when the light in not in use, easy to remove the lights, but I leave mine mounted, once dialed in, just some extra stuff they could sell...The light itself is awesome.
    I had read about the Double Strykr before purchase, about the low, medium, and high power settings, something like boom, bam and super bam...NOT REALLY, The Double Strykr is EXCELLENT ON HIGH BEAM, the other two setting, maybe a good night road option for extended battery life. Battery Life was excellent on high power, went over the 1.5 hour ridding time, still going strong.
    Mostly ride the XC trail, winding through the trees, tight turns dodging tree trunks, Nice to have the STRYKR SL on the helmet, to look around the upcoming corners with the STRYKR SL...same thing with the boom, bam and super bam, Not really, the SL works well on high beam, could get away just using the Strykr SL on a bar and helmet, and be better than most lights out their! However if you want the best of the best in my honest opinion I would go with the DOUBLE STRYKR ON THE HANDLEBAR AND HELMET, I haven't tried this combo yet, but the DOUBLE STRYKR was so good and twice as bright as the SL, when both in use, you could see the different light outputs. If I had to buy just one of the two, I would buy the Double Strykr.
    The Double Strykr had a nice anodized green finish, maybe like candy apple green, the Strykr SL had a heavy green paint, kind of ugly, and the anodized finish of the Double Strykr was so much nicer.
    If I could make a tweak to either Double Strykr or Strykr SL, it would be to have a programmable or variable light switch knob the user could adjust on the fly, not the step button click, low, medium, high, takes too long to go through the light settings, just give us a dial, so we can dial it in faster....
    Just my two cents worth....PEDALDOWN
