another MTE ssc 97 torch issue- Mtbr.com
Results 1 to 5 of 5
    mathlete
    Nov 2007
    The *high* mode on my MTE 2-mode P7 light quite working this evening. The *low* mode still works fine. Any tips on fixing this? I suspect is a bad tail switch. Anyone know where I can get a new one? Thanks - Remi
    Nowt to do with NKOTB!
    Reputation: Dirty Dawg's Avatar
    THIS might be of some help.
    Quote Originally Posted by cycleologist
    I wrote D/X once trying to buy a replacement switch/cap assembly. I never did get a response. There are web sites where you can buy the switch assemblies but of course you have to do the micro- soldering to do the repair. Sometimes the problem is just with getting good electrical contact. Lot's of times these things are easily resolved by tighting the metal O-rings on the switch assembly or pill assembly. Hopefully the link supplied by Dirty Dawg can help you.
    Jan 2009
    Quote Originally Posted by Cat-man-do
    hello from belgium (french speaking part)
    In my case, the PCB on which the switch ON / OFF is welded(in tailcap), was covered with glue. However, the metalic ring (of PCB) is needed to make contact with the body (it is the ground)...I just use a dremel-like tool to remove glue and now my lamp (MTE-P7) is working perfect (no more flickering at all).
    the link of Dirty Dawg helped me a lot
    thanks to this forum, because with your help I could build my triple ssc-P4 last winter, and repair my MTE-P7 this time
    arnold444
    Glad you got it sorted.
    I too find this forum a fantastic resource. Cheers folks!
