6x NCR18650B 10200mah 8.4V pack- Mtbr.com
Results 1 to 7 of 7
    RAKC
    Reputation: tigris99's Avatar
    Ok got my 6 cell Panasonic pack from Gearbest over the weekend. I'll load pictures tonight but here's the info I have so far:
    6 Cell Pack
    4 cell Pack
    Pouch for these is the nicest ive seen for China packs. One large wide strap that fits around about any bike frame tube.
    Did an initial charge and took forever, 5218mah. Started a discharge run just to check voltage sag and such. Everything is in order as it should be.
    Opened pack, Confirmed NCR18650B. Banks are properly balanced. Both read 3.68V prior to charge and 4.21 after first charge.
    Based on Ledoman's thread and findings from opening his pack, this pack is from same supplier. Assembly is the same, protection circuit looms identical, lack of kapton tape between protection circuit and cells.
    Its now confirmed: 6 cell pack is also good and real Panasonics. We now have 2 sources for the packs as I can now confirm the ones Gearbest carries are identical.
    Aug 2013
    Link, please!
    RAKC
    Ya sorry Archie, I was slacking lol. OP updated with links and pics.
    Nice to hear. What about good clear pictures of the PCMs and what cable it is used?
    Aug 2013
    Quote Originally Posted by tigris99 View Post
    Great; thanks!
    You like that outer pack?
    I have one and find it's impossible to tighten enough that it doesn't flop around.
    RAKC
    Compared to alot of what we see come with these lights, its alot better. Its alot more useable than the cheap crap ones we mostly see. Isn't great or perfect just A LOT better.
    That said, the flopping around issue is an easy fix. Piece of old tube and make sure pack is hanging. its how I made the crap Chinese pouches work before.
    @ ledoman: The cable on mine is 22awg, that's fixed already. Mine was shipped prior to making sure they all had 20AWG. I will take a pic later but I did compare what I had in my hand to your original pictures. Looks identical.
  1. Replies: 493
    Last Post: 01-22-2019, 11:01 AM
  2. Building Panasonic NCR18650B Super Max 3.7V 3400mAh pack 7.4V
    By pro_ohp in forum Lights DIY - Do It Yourself
    Last Post: 01-01-2015, 03:15 AM
  3. using a lumbar pack in addition to my hydration pack
    By androgen in forum General Discussion
    Last Post: 09-20-2013, 12:19 PM
  4. Pack In\Pack Out, spider trails on Somo
    By chollaball in forum Arizona
    Last Post: 02-01-2012, 04:35 PM
  5. Creative ways to pack your hydration pack?
    By hatake in forum General Discussion
    Last Post: 02-01-2012, 01:44 AM
