xml lens 18.5mm square or less?- Mtbr.com
Results 1 to 15 of 15
    Nov 2006
    I have some nice 1/8" thick rectangular aluminum looking for a project. The interior dimensions of the tubing are 44mm X 18.6mm. I was hoping to groove the tubing and build a double XML sled style bar light. I know that smaller lenses are not ideal but what would be some recommendations? Would I have room and would you recommend a triple? This will be used on the road and trail. I would like it to be a stand alone light for the road. On the trail I would probably use it along with a headlamp.
    thanks in advance everyone.
    andy
    Consider the Regina reflector. It can be slightly squished to fit in your tubing, or you can shorten to reduce maximum diameter.
    Thread using regina
    Nov 2006
    That's just what I wanted to hear! I haven't used a regina before but have seen the beamshots and always wanted to build a light using them. That sounds much better than settling on a lesser lens. Thanks!
    Reputation: znomit's Avatar
    XMLs won't throw well enough for a road light IMHO. I'd go with XP-E myself.
    Jun 2010
    +1 on the XPE for road. Your reflector area isn't large enough for an XML. In order to get a narrow beam from an XML, you need a much larger area for the reflector (or optic).
    Nov 2006
    OK, now where's the best place to get regina's? I can only find them on Cutter's website in stock. Any places in the US where I can buy small quantities? thanks.
    Jun 2010
    For Ledil Regina reflectors, you can try digikey.com.
    You'll have to check stock
    Nov 2006
    Yea, Digikey shows out of stock until the end of October.
    I think I have one spare kicking around if you want it - it's drilled out for an XM-L though.
    Nov 2006
    Thanks Matt, I'm in no hurry and need two anyway. Still undecided on XML or XPE.
    Quote Originally Posted by Andy13 View Post
    Split the difference...
    XPG
    even better, XP-G2 Should throw really nicely with a Regina.
    Pity your tube isn't a bit wider I have a really nice 20.5mm square optic at 10D FWHM
    [IMG]https://www.cutter.com.au/prodimages/100110d.jpg[/IMG
    The other alternate is the Carclo 10mm Square optics
    I would recommend for bike apps, go XPE-2, no contest
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    saw this on BLF, which might be an option. No idea on how good it is though.
    Such a shame you don't have just an extra 1.5mm to play with, then you'd have a whole host of optics to choose from.
    Just use a rattail file and take a bit off the inside of the tubing. You can get by with 1/16 walls. Since you have 1/8 walls, you have about 3 mm you can take off (and you don't have to take that off the entire inside surface--just where it interferes with the reflector). Just remember to not groove that area.
