Would like to get started with the DIY thing - Request for help- Mtbr.com
Results 1 to 2 of 2
    Sep 2014
    Reading these threads is difficult for me. I'd like to do a DIY headlight but want to start simple.
    It doesn't have to be super bright because my 17 dollar "Cree XML 1200" from amazon last year was bright enough.
    My night riding is usually cold, so thermal challenges might be diminished, plus I like to ride with the light at the low setting to conserve battery.
    My preference would be for a design that retrofits my current light housing, maybe with a new LED and driver. It might be easiest for me if the LED driver could be in the battery pack, and have new cold compatible wiring go straight up to the LED.
    For now I'm just replacing the battery pack and running the lights as-is.
    Another question, is an on/off switch a bad idea, or do they always fail in the cold?
    Reputation: deesta's Avatar
    I've just finished converting an old (round) Magicshine housing into a quad XPL-Hi. A bit of metal removal on the inside to fit the driver and it's really quite good.
  1. Help Getting (re)-Started!
    By Aristippus in forum General Discussion
    Last Post: 04-17-2016, 05:16 PM
  2. Getting Started
    By veridiux in forum Beginner's Corner
    Last Post: 07-13-2015, 10:50 PM
  3. Thanks for all the help getting started....
    By Knight511 in forum Lights DIY - Do It Yourself
    Last Post: 02-01-2014, 12:06 PM
  4. How do I get started?
    By MelvinoelGreat in forum Beginner's Corner
    Last Post: 02-24-2011, 02:56 PM
  5. Need a little help getting started.
    By [email protected] in forum Trail Building and Advocacy
    Last Post: 02-08-2011, 09:25 AM
