Wishlist: 22mm OD reflector for XML- Mtbr.com
Results 1 to 6 of 6
    Bigger is better!
    May 2005
    I wish someone could make a reflector for the XM-L with 22mm OD (to match the OD of star-boards).
    ==> A slightly larger Regina.
    Anyone else think this might be a good idea? Or if it would work at all?
    I wouldn't mind if it was deeper than the Regina, as long as the OD wasn't more than the OD of the star-boards.
    All of the star boards I've seen are 20mm dia which is fine with 20mm optics
    Use a different pcb?
    Bigger is better!
    May 2005
    Ah - I mixed up a little..
    The stars are 21mm tip-to-tip. And 22mm tip-to-tip if you measure the "invisible" corners. Which maybe you donīt...
    I wouldn't worry about what's not there!
    Bigger is better!
    May 2005
    Quote Originally Posted by JezV
    You might be on to something
