Will a hub dynamo power a ebay cree xml flashlight?- Mtbr.com
Results 1 to 2 of 2
    I got this idea that I could just solder wire leads instead of running it off a battery and power my cheap ebay cree xml t6 with the dynamo hub?
    Forgive my lack of electrical knowledge. Some thing about ac/dc non compatibility and regulating the power from the hub because it is fluctuating is my lack of knowledge here.
    Thx in advance.
    Reputation: znomit's Avatar
    These are a good candidate for dyno conversion because they are cheap and usually easy to get open.
    You need to replace the driver with a rectifier and smoothing cap. It will only run about 500mA so about 1/4 as bright as the original.
    You can improve this by replacing the XML with the 6V or 12V version (effectively 2 or 4 LEDs in series). The 6V will be 1/2 as bright as the original and the 12V the same brightness. But you lose low speed performance. 6V is the sweet spot for low speed performance and
    See here for some circuit options...
    Dynamo LED Light Systems for Bicycles (electronic circuits)
  1. 6,000 lumen 5 x Cree XM-L T6-LED cheap eBay light questions
    By spunkmtb in forum Lights DIY - Do It Yourself
    Last Post: 04-04-2016, 10:23 PM
  2. USB Port 1800lm CREE XML-T6 LED Bike - Need Power?
    By NH Mtbiker in forum Lights DIY - Do It Yourself
    Last Post: 05-06-2015, 05:01 AM
  3. Cheap Cree Lights, usually in pairs on Ebay
    By jekylljim in forum Lights and Night Riding
    Last Post: 11-14-2014, 05:45 AM
  4. CREE XM-L 1600 & 3800 lumen flashlights on eBay
    By ussprinceton2004 in forum Lights and Night Riding
    Last Post: 01-25-2013, 04:42 AM
  5. can anyone review ebay Cree t6 2 xpg r5 or comparables
    By laackund in forum Lights and Night Riding
    Last Post: 07-19-2012, 09:01 AM
