Will this charger work?- Mtbr.com
Results 1 to 5 of 5
    Hey guys,
    I purchased a tenergy battery pack (8 cell) 4400mah.
    I also purchased a charger, upon a closer look i found it says it will charge my 14.8v battery up to 4 cells. Would i hurt the battery if i tried to charge it using this charger?
    This charger was recommended at the bottom of the battery page.
    Battery pack:
    http://www.all-battery.com/li-ion186...connector.aspx
    Charger:
    http://www.all-battery.com/universal...v1-4cells.aspx
    Yes
    4 cells connected in series is 14.8v. Your pack is basically two 14.8v(4 cell) packs connected in paralell, doubling the capacity, but keeping the same voltage.
    Sweet, Thanks!
    Yea your ok on that one
    Reputation: yetibetty's Avatar
    I have the same charger and you will be fine, but as your battery is a double size pack it will also take double the time to charge.
