what type of silicon?- Mtbr.com
Results 1 to 10 of 10
    reading the MCE manual ( p9 ) I see they are sensitive to various adhesives / chemicals. What type of silicon are people using, acid cure or neutral cure?
    http://www.cree.com/products/pdf/XLa...ndHandling.pdf
    Reputation: znomit's Avatar
    Quote Originally Posted by rickh1
    Silicon? No, use a thermal edhesive such as this, it conducts the heat from the led to the housing and out to the air.
    http://www.arcticsilver.com/arctic_a...l_adhesive.htm
    oh, I meant for use in other areas of the housing, front panel, securing optics etc. I see troutie uses silicon on many of his projects.
    Keep the silicone away from the critical surfaces on the optics as they rely on the refraction at the optic air interface.
    Reputation: HEY HEY ITS HENDO's Avatar
    Ewwww keep away from the acid type!!
    delicate board traces and components dont like it
    neutral cure is the way to go
    ...Scun.thorpe, UK
    100% italian mtbiker
    Oct 2007
    go for the "neutral" silicon (the one that doesn't stink like cheap vinegar) as it doesnt have solvents in it.
    thanks for the advice guys.
    the only issue with the neutral cure silicon i have found is the cure time, 72hrs! just hate waiting to play with new toys...
    Reputation: yetibetty's Avatar
    Get everthing in place then heat with a hair dryer or switch the light on and let it get nice and hot and the stuff will cure very fast.
    thanks yeti, i need to do some temperature mapping for the housing so that will speed the cure time up.
    Alot of the neutral cure silicons need humidity as well as warmth for a quicker cure as they use the moisture in the air to kick off the cure.
