Water Bottle Battery Holder- Mtbr.com
Results 1 to 3 of 3
    A Man Of The Truth
    Reputation: fellsbiker's Avatar
    Every year I think how I need a better battery holder for my lights but I never have time to find a good solution. My new bike has one bottle holder spot and you can fit one of those smallish bottles into.
    So I use two cheapish amazon lights. The batteries come in little pouches that I typically independently zip tie to the frame. Then I velcro-tie the cables together. It's kind of a mess but it works as long as you leave it in there. But its a pain in the ass to remove them, and then reinstall them. Plus the pouches are so cheap, they tend to fail also.
    But I can't just toss the batteries into a bottle and call it a day. They'll be bouncing around like crazy and definitely get damaged and eventually fail. What I need is some way to store them in a bottle where they are held in position. All these little gimmickey biking nicknacks out there, you'd think someone would make something for this very purpose, a bottle-shaped battery holder.
    A friend once just put small strypfoam peas in there to pack it tight. I don't like this because it will help the batteries overheat in the summer. Plus the peas always get everywhere any time you open it. Other's had suggested you could 3d print a little frame of some kind.
    Has anyone come up with a good diy/hack solution to this problem?
    I use two of these lights: https://images-na.ssl-images-amazon....L._SL1000_.jpg
    The battery is in a pouch but you can slide it right out. If there was space in the bottle for the access light cable, I could clean up all the wire routing which would be really great. And I could take the whole thing off or put it on in a second or two.
    Check out my Mountain Bike Keychains on eBay
    MHC
    MHC is offline
    I bought a tool bottle to store a few spares, pump & tube.
    I had room for a 4S Li battery so fitted it inside using a waterproof cable gland.
    Sep 2018
  1. Coffee/Beverage holder for water bottle cage
    By Jason Rides Bikes in forum Commuting
    Last Post: 06-05-2018, 06:57 AM
  2. For those who all want a new water bottle holder
    By deke505 in forum Off Camber (off topic)
    Last Post: 03-17-2013, 07:14 PM
  3. What water bottle holder for my 29er?
    By AC/BC in forum test forum
    Last Post: 02-05-2013, 03:18 PM
  4. Water Bottle holder for '06 Enduro?
    By Tarekith in forum Specialized
    Last Post: 06-23-2006, 12:30 PM
  5. Mounting a water bottle holder
    By zoink in forum General Discussion
    Last Post: 11-24-2004, 12:17 PM
Members who have read this thread: 31
