Twin XPG headlight- Mtbr.com
Results 1 to 5 of 5
    Twin XPG headlight
    Here is my latest headlight - twin XPG's with regina reflectors in a homemade alloy housing.
    There are 2 resistors in the middle bit (which is a small plastic box from Maplin), a 0.5 ohm giving something like 900mA on high and a 10 ohm giving something like 200mA on low.
    Powered by a 2 cell pack on the back of the helmet.
    I did try running it without any resistor on high, it pulled 1.2A and got incredibly hot to the touch so the resistor went in to keep things a bit cooler.
    I am very happy with the home anodising - the finish came our really well.
    Attached Thumbnails Attached Thumbnails Twin XPG headlight-img00254-20101113-1133.jpg
    May 2010
    Great colour!
    May 2005
    Construction details if you please? Particularly, what is the center section made from. It looks like you have it wrapped in a piece of innertube.
    A waste of time it is is
    Reputation: emu26's Avatar
    Nice looking light and +1 on the construction details, particularly how you hold it all together
    Quote Originally Posted by Vancbiker
    The centre box is the minature one of these - and yes well spotted there is an inner tube sleeve over it to help protect it from knocks, it does look a bit scrappy so I will probably cut it off.
    The barrels are turned from alloy tube with a small lip at the front to retain the perspex and the 'o' ring.
    The XPG are on stars and sit on a heatsink made out of alloy bar, which is held in the barrel by the hollow tube which passes through the center box.
    I should have got some photos before it went together!!
