Switch failure on Magicshine HA iii - Help!- Mtbr.com
Results 1 to 3 of 3
    Dec 2010
    Hi
    My Magicshine light has developed a fault. The "clicky" switch has become unreliable. It works for a while then stops working again. I think it is worse in cold weather. The switch is an intermittent contact single pole job so I think it is the circuitry behind it that is the issue. Any ideas which component might be failing?
    Mike
    Reputation: HEY HEY ITS HENDO's Avatar
    Hey Mike, i`m not familiar with that light, but
    even if the switch is suspect, take the light apart and look for any other possible faults first
    ie water ingress, loose connections then check the switch
    intermittent faults are a pain to trace
    i`m sure new switches are available from somewhere though
    anybody ????
    ...Scun.thorpe, UK
    Dec 2010
    I think that most LED torch lights work in a similar way, the switch provides an contact briefly when it is pressed but the circuit uses this as a signal to change state. Although I have this problem with my Magicshine now I have had the same problem on several other cheaper torches.
    Mike
