Supernova taillight repair- Mtbr.com
    Randomhead
    one of the three LEDs on my Supernova taillight burned out looks like this: LINK Any ideas on what to replace it with? It's 4 years old, don't really want to send it back to Germany anyway
    RAKC
    Reputation: tigris99's Avatar
    Just a 5mm LED of whatever color you need. Those are pretty basic leds, used in EVERYTHING, so find a 5mm in the color you need, unsolder the burned out one and replace it. Just make sure you have it in the right way for polarity before you solder it in.
    Reputation: znomit's Avatar
    They are in series I think? I don't see how one can burn out on its own. I see they use leds with red encapsulation now so a factory fix might mean a better light. I'd be using the 5 year warranty.
    But if you are DIYing it, ideally you want to match the colour and the beam angle, but in practice just find the highest current and tightest beam angle red you can. If you get one with a low current capacity it will be nice and bright when you hook it up but dim quickly with use.
    Randomhead
    didn't realize they had a 5 year warranty. I have seen an LED not put out light but still conduct, I had a headlight do that. Not sure how it works
    eta: thanks for pointing out the warranty. It's getting replaced under warranty.
  1. DIY Bright Rechargeable Taillight?
    By rjcarlson49 in forum Lights DIY - Do It Yourself
    Last Post: 09-22-2015, 10:41 AM
  2. Supernova E3 Taillight 2, what rack is this?
    By seth586 in forum Lights and Night Riding
    Last Post: 04-28-2013, 12:20 PM
  3. Best taillight?
    By Dr.Mushy in forum Lights and Night Riding
    Last Post: 11-21-2012, 09:35 AM
  4. Taillight attempt
    By wiggy in forum Lights DIY - Do It Yourself
    Last Post: 05-06-2012, 03:35 PM
  5. MS 900 converted to taillight.
    By stumblemumble in forum Commuting
    Last Post: 03-08-2011, 06:20 AM
