SST-90 or XP-G- Mtbr.com
View Poll Results: SST-90 or XP-G? Which one would you go with?
Voters
17. You may not vote on this poll
  • SST-90
    0 0%
  • XP-G
    17 100.00%
Results 1 to 8 of 8
Thread: SST-90 or XP-G
    SST-90 or XP-G
    Has anyone built a light using sst-90? I tried searching but nothing came up.
    Also, between sst-90 and XP-G, which would you recommend?
    I need it to last me about 3 hours. handlebar mount, I have all variety of batteries I can use.
    where will you be riding? and if you use xpg will it be more then 1?
    May 2005
    SST-90 is less efficient and has fewer optics choices than the XP series. It has a huge die which typically requires an equally huge reflector or optic to harness the light into a useful beam. Pretty significant drawbacks IMO.
    I want to mount this on a handlebar. I was thinking either 3x xp-g or 1 sst-90.
    I would go for xpg even on full it would draw half the power og the ssc90 and the light would sertainly not be bad
    Do It Yourself
    Reputation: Homebrew's Avatar
    Go with the XP-G or wait for the XM-L.
    Long Live Long Rides
    Quote Originally Posted by Homebrew
    XM-L looks very good, but I'm sure it'll be $$$ when it first comes out.
