Spider Eyes- Mtbr.com
Results 1 to 24 of 24
Thread: Spider Eyes
    Idea! Spider Eyes
    A bit of experimenting for when the XP-G leds hit the shelves .
    If they run cooler and put out the projected lumens a tiny hi powered helmet light will be great.
    I got these 12 mm aspherics and have been having a play with them but wont know what they are like for a few hours untill it gets dark .
    fool goin up, joker down
    Jan 2009
    I can't tell by the picture, but are the lights pointing is slightly different directions or are they both facing forward
    Mamma speed I'm back!!!
    Jan 2009
    I can't tell by the picture, but are the lights pointing is slightly different directions or are they both facing forward?
    Can't wait to see what the beam pattern will look like. With two XP-G's output should still be over 600lm. Even with XP-E's it should be interesting. I'm glad to see you are still experimenting with minimal (light weight) builds.
    Spanish biker
    Reputation: msxtr's Avatar
    Hi, what aspherical lens are those? link, please...
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    lookin good mr T
    joys of summer and waiting till it gets dark, you could be making a mating half whilst youre waiting
    Quote Originally Posted by msxtr
    Greetings - Saludos
    msxtr
    Linkypoos here
    Cant wait for it to get dark . probably be rubbish and too narrow
    Go faster!
    Reputation: sergio_pt's Avatar
    yep they look pretty cool! can you post more pictures of the light? Do you have the driver in the light body?
    Quote Originally Posted by sergio_pt
    There is nothing else to see yet untill I see what sort of beam it gives out .
    just on a bench power supply
    I suspect it will be a very narrow beam more suited to fitting on a gun than a bike helmet
    It is more a bit of experimenting and I might try one on a MCE later too .
    Reputation: Billabang's Avatar
    Test 'em in the closet.
    Here is the beam shot .
    bear in mind the trees in the back ground are 75 metres away and the ones right at the back are 150 metres
    so not bad for a little light
    Go faster!
    hmm maybe you need an 8 eye'd spider
    but still impressive compared to leds this time last year.
    you'll be mounting them directly along the stem next with a switch within the grips
    Reputation: HuffyPuffy's Avatar
    Looks cool, is it using XP-E's?
    Great experiment Troutie!
    sorry for my missunderstanding but are you using XP-G leds for the spider eyes? or which led?
    lovely narrow beam.....would be great to test it on an MC-E!!!
    Reputation: znomit's Avatar
    Nice Troutie.
    Any chance of a beamshot up against a wall?
    And I just ordered a tight optic from cutter last night. Grrrr.
    @ that .
    Whitedog
    I wish they were but sadly no just the XP-E R2
    Znomit .
    Will do but need to wait for tonight also want to compare it with 2 of the narrow tight optics.
    The aspherics are a bit of a faff to get the focus right I have these slightly defocused to get rid of the die shape a little.
    Quote Originally Posted by troutie-mtb
    ...The aspherics are a bit of a faff to get the focus right I have these slightly defocused to get rid of the die shape a little.
    All things considered, I think you did one heck of a job.. Even with the XP-E's it is damn bright and with great throw! With XP-G's it should be even better. Most people probably don't like the narrow beam but I think it rules. One of these on the helmet and one ( or maybe a 3-up with more standard optics ) on the bars would be a really great set-up for endurance events...not to mention also for those of us who are real weight weenies.
    Ok here is the shot against a wall . well target with sizes on .
    Why dont the darn manufacturers do that then we would have a better idea of the beam.
    anyway the sizes are in mm and the outer is 1 metre diameter.
    distance from light to board is 2 metres.
    first up is the carclo 20 mm triple tight
    then the spider eye double.
    it can be focused even more to get a tighter beam but then it becomes a projection of the led die..
    and last now this is tight
    the Khatod 20 mm aspherical on an XPE
    I will add a shot with 2 of the Tight square optics later.
    Any chance we can see what the Khatod 20mm aspheric optic looks like? That is one tight beam!
    Quote Originally Posted by Cat-man-do
    I think:
    http://www.cutter.com.au/proddetail.php?prod=cut745
    The cutter links to Khatod datasheets are old and busted so here you go:
    http://www.khatod.com/Documenti/kepl...est_report.pdf
    Single Speed Junkie
    Reputation: crux's Avatar
    Thought spiders had eight eyes.
    That is really cool. The XP-G sounds ideal for cycling applications I just hope we can get the heat out of the emitter with the small die size.
    I love that picture
    2 MCE with the Kathod aspherics and 2 of the 12 mm one with xpes for a jumping spider light.
    Be a good one for BBruno in Brazil.
    Reputation: BrunoBB's Avatar
    Troutie:
    I canīt stop thinking about the Insane Light but iīd like to see a shot this set (2 MCE with the Kathod aspherics and 2 of the 12 mm one with xpes) at the woods.
    Bruno
