Small powerful Headlamp - 1xXML2, 1x18650 li-ion- Mtbr.com
Results 1 to 14 of 14
    Jun 2013
    Hi folks, I am starting this thread about prototyping of a new powerful and lightweight headlamp. Its nearly exactly 1 year after introducing Lucifer headlamp. This new headlamp is smaller and lighter than previous model and has greater supply voltage flexibility as it can be used with one 18650 battery, two or a pack of four. Its meant for orienteering runners, adventurers or for mtb bikers as a superior helmet light. It should meet following specification:
    Specification:
    Body: cnc milled aluminium aircraft alloy hard anodized
    Led: CREE XP-L, HD, 5000K
    Optics: TIR 16
    Battery: 1x18650 Panasonic 3400mAh unprotected (battery container is openable and has got protection circuit),
    Electronics: our own buck converter made of discrete components and driven by Atmel 8-bit MCU with efficiancy up to 95%, has got temperature protection, overdischarge protection and protection against opposite polarity
    Modes: 5 + blink
    Lumens: 25 850lm (max. mode is not time limited)
    Runtimes: 85 1 hour
    Weight: 150gr.
    Waterproofness: IPX-8rating (1m submersion)
    Overall its very tiny package so there is nearly no space for electronics, switch and optics. Also waterproofness could be little hard. I would like to have the front cover made injenction moulded from ABS plastics but it could have some flex in it not to press o-ring hard enough to seal it perfectly. If if will not work, then I will made them from aluminium as well.
    Here are some pictures of the first design model, hope you like it. Ithink about adding little more cooling ribs, but I will decide after I got real working headlamp in a hand a test it in real conditions.
    Electronics is my own electronics which I developed for regular Lucifer headlamp but with decent changes as it was originally made for 2 LEDs and also 2 battery cells in series. Now it should handle both 1-cell and 2-cell li-ion batterypacks. The main difference is faster PWM with higher resolution. Now its 62Khz with 10-bit resolution because of higher step down factor. Otherwise steps would be very high andnoticeble. Faster clock should help me get there smaller inductor and leave place for decent 5x5mm switch.
    Battery container for 1 li-ion 18650 cell is basically tube with some milling and threading. Im curious how this will work as I dont have any lathe, only a cnc mill which is not best choice for this kind of things. Sealing will be done with O-rings as any other flashlight out there.
    Weight 18.34gr
    Weight 8.55gr
    Crosssection of battery container with battery, protection circuit and springs inside
    Attached Thumbnails Attached Thumbnails Small powerful Headlamp - 1xXML2, 1x18650 li-ion-headlampcreexml.01.jpg
    Jun 2013
    Aluminium arrived and we started machining. First come both caps of battery container. For both of them I need to make custom fixtures.
    Cap with a hole for a cable gland was easy, its has got a hole where you mount a screw. I made similar thing few times before so I didnt expect any troubles with it. It went smooth and after a day of machining I got 14 pieces, 2 of them made with crossection by a mistake.
    Thread inside is milled with a 4-flute tiny threadmill tool. Im little afraid about the proper size of the thread as it will get bigger with anodizing process. Im also thinking about sandblasting all these pieces as it could give them better finish.
    Cap without hole was little harder. I made 10 of them from one side a separate them on bandsaw. Then I made fixture plate for 5 pieces with thread. Caps were screwed on this fixture and clamped with a sleeve. Otherwise caps could be unscrewe by machining forces.
    May 2005
    Nice looking work and enjoy the opportunity to see your fixturing ideas.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Jun 2013
    For the main part of batterypack container we bought aluminium tube 19/22mm wide. So the side is 1.5mm thick and one typical 18650 li-ion cell fits there nicely, even protected one (which has got a bit higher diameter than unprotected).
    We have to machine them 2 at once in vise so they will not loosen and come out of vise. We do first top side and them turn them over and machine second side. Its crucial not to tighten them in second operation so much, so thin tube will not deform. Tube is almost fully sunk in V-block jaw and still vibrates little but. Its not perfect but quite acceptable. When you pull little more of it outside vise, tool starts to vibrate a lot. Thread is milled with a threadmill which is bautiful carbide tool with 4 teeths.
    We think over machining our own high jaws with profile for these rounded parts so we dont deform them anyway.
    We also tried sandblasting on few parts. Maybe its not visible on photos right now but I think it will be large difference in final look after they came back with black anodizing finish.
    Jun 2013
    Some new pictures, I am working on it hard. Headlamp body is completed. I wasnt succesful for first attempt because I drilled through the whole body when I was doing mounting holes. But second time I got it right.
    Reputation: Wombat's Avatar
    I appreciate that you document what you're doing.
    A question about the light on your site:how does it mount to the bars?
    Tim
    Jun 2013
    Size and weight comparison to our regular Lucifer body. Difference only in aluminium body is 10gr., but in the end it will be much higher. Target weight 160gr including all is achievable.
    Third pic is tube with somekind of stainless steel finish. Sanded version unfortunately doesnt look so good (see on previous images).
    On few other pictures is driver. PCB is being made and come to us next week. For these prototypes we will solder and place components ourselves. Its switching buck converter and operates from 2.5V to 9V, so it can use both 1-cell and 2-cell li-ion batterypacks.
    RAKC
    Reputation: tigris99's Avatar
    Alot of really nice machine work here. Not a fan of the design of the single emitter head only because its bulky imo. But regardless its really nice work, well thought out and clean.
    Like the looks of that dual emitter head though, am curious how you correct the thermal path since the entire inside is hollow?
    And your design work on the driver is job well done. Wish I had the abilities and know how to make my own drivers
    Jun 2013
    tigris99: Dual emitter head has got LEDs directly soldered to a piece of copper. The heat is then transferred to outter aluminium body. Its maybe not visible from this angle but it has got enough surface where both touch.
    Wombat: Bar holder is not for sale now, will be autumn/winter. We have made 4 or 5 prototypes to ensure that it will be rock solid and stable.
    Jun 2013
    Hi, here is update. Parts came back from anodizing and threading fits together really nice. I put there three different finishes of a tube for comparison and I think clear winner is sandpaper finish which looks little bit like stainless steel.
    I hand soldered electronics which was difficult due to DFN and other tiny packages but was still manageable. It took some time to check if connections are right and correct them with hot air if not. Circuit is mostly same as large headlamp circuit but there are special ICs which enable use of 1cell or 2cell li-ion batteries (2.5V-8.4V). MCU has got different code as well, it has to determine appropriate switching PWM for both cases. So far its working well, needs further testing though.
    From mechanical side of view there are few changes that need to be made. Threading is smooth but entry of it needs more work. The second thing is design, I do not like it much and I want to do changes to make this headlamp pretty. Optics and LED will be centered, overall shape will be more chamfered. I start machining next week and new PCBs is already being made.
    Spring is strong gold plated spring with resistance as low as 2-3 miliohms.
    Front part is 3d printed from black ABS, it will be injection moulded. Screws will be allen screws.
    RAKC
    Actually to he completely honesty I wasn't too intrigued by this till now! I obviously didn't see your vision at first.
    You may not like the way the head looks but I do. ITS DIFFERENT. Only thing I would change is the front plate looks plain. Some machining next to the optics to add a bit of "style" and I would leave the rest.
    Making the led "centered" is what everyone else does, doing something different to me is what makes something awesome instead of "just another light"
    Jun 2013
    Hi, here is long waited update. Why it took so long? Because the first concept was wrong and LED was not able to cool at that power. That meant, everything had to be redone from a scratch and that took some time. Also came season and there was no spare time for improvements and news.
    And now only good news. Headlamp is fully functional, need only slight changes in driver uController program. It lights a lot and more than I mentioned previously because it has got better diode - XP-L HD, 5000K, bin V4, CRI typ. 75 and puts out 850 lumens (after heat and optic losses substraction). LED is - as always - directly copper soldered. Efficiency of electronics is between 90-95%, its little less than our current Lucifer M3 but sill very high value. Its not measured but based on measurements of one older nearly identical electronics. TIR optics has got 93% light transmittance and is very short so the whole headlamp is quite compact. Beam of the light is very pleasant without any artifacts with FWHM angle 16.
    Total weight (with included 1x18650 battery) is 150 grams. Head itself weights only 13 grams and has got massive cooling fins. Headlamp is very stable on head in every situation.
    And now photos which tell more. On first one there is intermediate prototype which was much bigger and with large optics which was not needed for this diode. Button will be located in the front part as you see it now. Other photos show the last prototype model which will be nearly the same as production one. There is missing front optics holder, we are waiting for 3d prints. Front part will be made from plastics but will have ribs on the opposite side to be stronger. Optics will be attached with transparent UV curing glue.
    Further details (light output, modes, runtimes) can be found on our site: www.luciferlights.net/headlamp-lucifer-small which will be updated. This headlamp is mostly for runners, adventurers and tourists. Can be used for dry caving. Price is expected to be 92Euro without battery and charger. 18650 batteries can be used unprotected. Charging would be possible also from USB port with small accessory - no need to put the cell out of battery tube.
    Jun 2013
    Here is it with 3d printed front part. This one will be injection moulded on final parts. There are still small changes that needs to be made to fit perfectly.
    Screw would be stainless steel allen screws, I temporarily used these because I did not have 5mm size available.
    Jun 2013
    Recent photos. Slight upgrade on battery tube. Caps are now hexagonal instead of circular ones. Its much easier to manipulate with them. Threading is much better, I am convinced that it cannot be done on a mill better. There is also new surface finish - shot peened. I am quite happy with it and real life experience is much better than these pics. Surface is uniform, without any milling marks and still very smooth. On last photos there is comparison before and after on a headlamp model Lucifer M. Whole tube is gonna be black anodized, maybe also with laser marking logo.
  1. Powerful LED Headlamp & Bikelight, LEDs directly soldered to copper
    By sirpetr in forum Lights DIY - Do It Yourself
    Last Post: 04-13-2019, 03:45 AM
  2. Crelant headlamp
    By ridingcool in forum Lights and Night Riding
    Last Post: 11-09-2013, 01:50 AM
  3. high CRI all in one headlamp
    By mattthemuppet in forum Lights DIY - Do It Yourself
    Last Post: 08-29-2013, 06:03 AM
  4. Looking for a new headlamp
    By DisrupTer911 in forum Lights and Night Riding
    Last Post: 05-23-2011, 09:34 AM
  5. 170,000 lux headlamp
    By c-rider in forum Lights DIY - Do It Yourself
    Last Post: 01-15-2011, 06:45 PM
