shorting one led from two in serie- Mtbr.com
Results 1 to 14 of 14
    Hello,
    I am thinking on making a light with two or more leds in series and adjusting brightness using switch(-es) which are short circuiting some leds. The question is: will a driver adjust the power quick enough not to burn other led?
    Reputation: znomit's Avatar
    Quote Originally Posted by Itess
    Hello,
    No. You will destroy led2.
    If you want dimming use a driver that halves the current.
    Quote Originally Posted by znomit
    Thanks for the warning. I was afraid of that. I want to switch not only dimming, but light configuration also.
    It is possible ONLY if you switch off the light completely.
    Quote Originally Posted by zemike
    Good idea.
    A four pole on/off/on will do this for you
    Interesting. Now I am thinking of some way to shutdown the driver when pressing the switch.
    A driver with dimming capability is the only way you're going to manage this. Most LED drivers use current mode control, so if you have a 1A driver, it will source 1A of current to the LEDs. Let's say your LEDs have a forward voltage drop of 3V at 1A. If you closed that switch, 6V would appear across LED2 briefly, and would cause it to fail.
    If you wanted to achieve the same effect without blowing up the LED, you could parallel the LEDs and then open circuit one of them. However, each LED would then be getting 500mA with both connected, and when you opened the switch, the current in LED2 would increase to 1A (with the assumed 1A driver).
    If you went with the parallel configuration, and simultaneously halved the output current of the driver, then you'd get the desired effect.
    Quote Originally Posted by shinkansen
    Yes, I thought about that, that's why I asked.
    Actually, I was thinking of 3-4 leds with differen optics with 2-3 switches.Now I think it's possible with a very custom driver for which I don't have the knowlege. I have to think of something else.
    You could go with several small micropuck drivers (http://ledsupply.com/micropuck.php) and just switch them on and off individually. A guide for a light using these drivers is at http://www.racedaynutrition.com/Features/bikelight.aspx; you may have already seen it.
    Well, yes, I thought about several drivers. I saw several drivers efficiency diagramms, and usually with 2-3 leds drivers are more effective than with one. And it's pretty critical to me because 4 XP-E with 4 drivers with 80% efficiency will reduce runtime and heat the environment more as with one driver and 95% efficiency.
    The micropuck is fairly efficient in buck mode, with an efficiency of around 90% between 4 and 5.5V input. I agree with you though, it's not an elegant solution and certainly not the best.
    MicroPuck Online Data Sheet does not agree with you
    Yes, multiple micropuck drivers aren't best and certanly not elegant solution. But thanks for bringing this up, it was a fun to think a little bit more in this way.
    You'll need to read the application notes for the buck mode characteristic - http://ledsupply.com/docs/MicroPuck-Applications.pdf
    I'll let you know if I think of anything else
    Its not just driver efficiency, its LED efficiency too. LEDs are much more efficient at low currents.
    ie running 1 led at 1A is much worse than running 4 at 250mA... 50% more efficient
    The only reason to switch individual leds is if you want different beam patterns.
    Here I use a flood and a spot
