Screw-in power cable thingies...- Mtbr.com
Results 1 to 8 of 8
    Reputation: deesta's Avatar
    Can't for the life of me find any screw-in type power cable fittings.
    Looking to do a better fixing power cable for my new light, rather than a 2.5mm DC push in as I want to mount the power from the bottom.
    Anyone point me in the right direction (UK) preferably :-)
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Pico M8 3 pin connectors.
    They are a standard connector made by a bunch of different companies... LUMBERG, Turk, Murr, etc. You can get pre-wired male and female cables as well as panel mount connectors: 7000-08552-9700050 | Murrelektronik Limited 7000-08552-9700050, M8 3 Pole Male Front Mount Circular Connector,Male Contacts, IP67 | Murr Elektronik
    Check on eBay too, that's where I got Lumberg ones I use on all my high power lights.
    They aren't meant for very high currents though... most are spec'd at 4A max although there is also a 4 pin variant of them that you could double up the wires to get 8A current capacity. Waterproof and very durable... used in industrial environments for connecting up sensors on equipment.
    May 2005
    +1 on ^
    I've used the Turck panel mount M8 connectors on my lights for several years. Bulletproof reliability. As Kwarwick mentioned they are a bit low capacity for todays higher powered LEDs. I'm runing mine at a maximum of 3.5A currently. No problems but I'm sure there is a bit of voltage drop.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Thanks chaps, I'll have a look
    RAKC
    Reputation: tigris99's Avatar
    I use these, voltage sag minimal. Waterproof etc.
    http://www.amazon.com/gp/aw/d/B00I2E..._bc_B00I2EOK7A
    RAKC
    I have to say I want longer, guess I need to dig around eBay. The ones I bought are just barely long enough for my bar light. And forces me to put pouch on top of TT instead of hanging under it or on down tube.
    Feb 2015
    Just wondered what you bought to use? Need something myself but most of the cheaper ones on eBay don't give much info, don't really want 24awg cable :P
  1. Fox Dyad RT2 Cable Set Screw
    By D(C) in forum Cannondale
    Last Post: 03-25-2014, 11:15 PM
  2. Which screw do i loosen to remove the shifter cable?
    By TheeSuperUberV in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-25-2013, 01:33 PM
  3. Front derailleur cable clamp screw is stripped
    By rick5587 in forum General Discussion
    Last Post: 06-13-2013, 11:40 AM
  4. FD Cable Tension Lock (Screw and Nut)
    By jinda in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2012, 06:55 AM
  5. Replies: 6
    Last Post: 03-16-2012, 07:54 AM
