Replacement battery for Cygolite NiMH?- Mtbr.com
Results 1 to 6 of 6
    Reputation: Ofroad'bent's Avatar
    A friend 's Cygolite Triden-X NiMH battery seems to be pooched. It's 6v or so. Think this one can be DIY'ed with a 7.4v lithium and some new connectors, or will I blow it to smithereens?
    I'd appreciate the official Light Geek upgrade for this light.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Did you call Cygolite and ask them how much a replacement would be? Support folks there have been quite helpful in my experience.
    Reputation: HEY HEY ITS HENDO's Avatar
    the cheapest option is to make up another Ni-mh pack
    there wouldn`t be a gain going li-ion
    as you would also need a compatable charger
    just swap out the plug on something like this ...
    HPI Racing RC Baja Plazma 6v 4300mah NiMh Receiver Hump Pack Battery 101937 | eBay
    ...Scun.thorpe, UK
    I don't think the NiMH and Li-ion versions of the light head are different, so upgrading to a 7.4V Li-ion battery should be OK. The driver will adapt to the higher voltage automatically. The problem, as mentioned by Hendo, is you'll need a special Li-ion charger.
    Thanks guys. I'll see if he wants to try NiMH or Li-ion and new charger.
    I have an old cygolight. After the original 6v lead acid battery died, I used to run it on 6 x AA for a nominal voltage of 7.2v which gave an appreciable improvement in brightness.
    Flogged the AA's to death though as the current draw was a bit high. I looked at going to C or D size NiMH, but the cost was that high I started looking at alternatives, which led me to here which led me to LED.
    I still have the cygolight as an emergency back-up - should the three LED's I now have all fail. I simply wired in a magishine plug & can run it off the 7.4v battery packs. Running the globe at higher voltages gives you more heat, more light & reduces globe life, but not so much that I would worry about it.
    It's a pretty small investment to buy a lion pack & charger & gives him the option to upgrade to an LED if he wants to later on
  1. looking for replacement battery for Nimh 6 V 4.0 Ah TurboCat lights
    By RUNDCM in forum Lights and Night Riding
    Last Post: 08-23-2011, 04:29 AM
  2. Replacement Battery for Cygolite
    By Riding In Israel in forum Lights DIY - Do It Yourself
    Last Post: 11-17-2010, 03:09 PM
  3. Niterider NimH Replacement Battery
    By Albanach in forum Lights DIY - Do It Yourself
    Last Post: 02-11-2010, 03:46 AM
  4. Cygolite HID Replacement Battery?
    By meridesNRS in forum Lights DIY - Do It Yourself
    Last Post: 11-16-2007, 10:15 PM
  5. Replacement Light and Motion NiMH Battery advice
    By iggs in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2007, 05:16 AM
