Regina and XPG- Mtbr.com
Results 1 to 17 of 17
Thread: Regina and XPG
    Reputation: bncrshr77's Avatar
    Regina and XPG
    Are there any specific XP-G boards I need to match up to the Regina reflectors. There are a bunch of different stars/boards out there and I'm just wondering. Thanks..
    You have to pull the tabs off no matter what from what I've seen. They don't seem to match up to any pcb that is readily available. If you grab a 14mm or larger pcb then you don't have to worry about cutting a channel for your wires.
    Thanks for the info!
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by bncrshr77
    This is the only board I've found that matches up with the locating pins on the Regina:
    http://www.led-tech.de/en/High-Power...8_120_138.html
    Nice
    Not $8.50ea nice but I'm sure it serves a purpose to someone
    Anyone know where to buy boards in the U.S. even if they don't match the locating pins? 14mm would be best but might take whatever.
    Reputation: ScottParsley's Avatar
    http://ledsupply.com/indusstar-1up.php
    Just got two XP-G 20mm stars and some other stuff. Only took a few days and my order was correct. No problems.
    I just cut the legs off the Regina and very carefully glued it on.
    Or carefully drill a 20 mm star to suit with a 1.5 mm drill
    I've never messed with the boards before....Would it be possible to shave the INDUS star board down to 14mm or would that ruin the electrical contacts? Sorry for the stupid questions.
    I do like the idea of drilling your own holes...That's something I can manage!!
    Quote Originally Posted by troutie-mtb
    I'm trying to see the benefit in this compared to the time it would take to carefully measure and drill holes to directly center the reflector over the LED?
    Quote Originally Posted by kan3
    The benefit was purely for the customer ,
    carefully measure once and make a little Jig so I could do the other 200 I was supplying as a little kit to folks to do a hammond box light .
    but now I have the jig it is easy .
    nice
    May 2010
    I noticed that over at STW - bit of a monster thread ;-)
    bncrshr77
    Just cut the frickin legs off your Reginas, and glue them to the stars.
    And don't bother with 10 or 14 mm stars - 20 mm is our choice
    Quote Originally Posted by klynk
    bncrshr77
    The issue of fitting to reginas to the stars is solved...My problem is that I only have 15.8mm of room to fit a 20mm star in....That's why I was looking for the smaller boards or wondering if I could shave the 20mm stars down somehow.
    You can shave the board down to the desired size and use the contacts on the led, but you would have to make grooves for the wires in the bottom of the reflector an make sure the star doesn't short via housing.
    Think I've got all the answers I need now....Thanks fellas!
