RED, RED-Orange XP-E tail lights- Mtbr.com
Results 1 to 7 of 7
    I saw data sheets for cree xp-e leds in color.
    Looks quite good. I am already thinking about new tail light builds with these. The 10mm carclo squares and 20mm round triples along with some electrical voodoo would be nice. A flashing circuit for alternating color or beam angles. 60 lumens form a red-orange device at 350ma is much better than a luxeon rebel. I am picturing something resembling a light bar that is the size of a 18650 battery with a 18650 battery behind it.
    3 10mm carclo squares in a line a Blinking UI constant current regulator in the same line and then a small switch. It could all be stuffed into some 3/4" 19mm box tubing or milled out of 3/4" 19mm barstock.
    Been wanting to build something with those XPEs as well. Cutter has been out of them for a while now.
    Do you know of another source???
    Reputation: yetibetty's Avatar
    I like the idea, I ended up with a few of these little housings when I was learning/practicing on my micro lathe and they make great XP-e tail lights(driver in battery pack).
    It has to be done for the pleasure of making things though, as we all know you can get a good ready made tail light for next to nothing these days.
    I use an external battery as an 18650 or two fits just nice between the saddle rails.
    Reputation: znomit's Avatar
    Quote Originally Posted by yetibetty
    A litle bigger and they would hold a micropuck
    Yes I've been watching cutter for the red XPs too.
    On the same subject what battery and regulators are people using for tail lights?
    I have really only used DX boards which are unreliable and run hot.
    I thinking about this for the project posted above.
    http://www.kaidomain.com/ProductDeta...ProductId=5313
    Hi Guys
    XPE colours due for release soon, still in early eng sample stage at present
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    Quote Originally Posted by bikerjay
    Hmmm, they look pretty good, especially the multi mode, 3 Hz is probably quite good, assuming they work( the feedback isn't very positive on this).
