quad xpl bike light, not sure of lumens, comments/critizism welcome.- Mtbr.com
    4 Cree XPL, H supposed to be 1150 lumes each. buck puck 1000mah, 14.4 battey, 2 carlo med spot in medium in middle 2 carlo wide spots on outside.
    not sure what the final lumen output would be, not an electrical engineer, just faking it.
    if you can figure it out, let me know.
    i dont like my toggle switch, seems delicate. any suggestions on different switch im all ears.
    last light i made was 8 years ago,
    thanks
    sean
    Attached Thumbnails Attached Thumbnails quad xpl bike light, not sure of lumens, comments/critizism welcome.-20181125_095151.jpg
    quad xpl bike light, not sure of lumens, comments/critizism welcome.-20181125_095201.jpg
    May 2005
    Been a long time since anyone has posted a pipe cap and hobby box build. Buck puck too.
    Depending on the tint and bin of your XPL-Hi emitters, at 1000mA you're going to have at most a bit under 2000 lumen at the emitters. Optic losses will drop that to ~1700.
    The XPL-Hi is rated at 3000mA so you have room to bump it up with a better driver.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Thanks Vancbiker, 1000mah driver is the biggest one I saw. Also, my battery is 3500 mah so I was thinking it would be bright enough for a long time (long night ride, with getting lost or mechanical) Do they make a 1500 mah driver? maybe a happy medium?
    thanks again.
    May 2005
    Been about 7 years since I last used a buck puck so I don't know what they have anymore. The high setting on my dual XML-Hi light is 3500mA with a Taskled LFlex driver. It's around 2000 lumen at that current but I only use the high setting on fast sections.
    At the current you are driving you are the sweet spot for output versus current draw. Notice that I have to run more than triple the current on 2 LEDs to barely exceed the output you are getting with 4 LEDs.
  1. Opinions/reviews on the Dinotte XPL-3?
    By rlb81 in forum Lights and Night Riding
    Last Post: 04-18-2017, 12:36 PM
  2. WTF - The Quad SST-90 (SSR-90) Light 8,600 lumens
    By cosmoworks in forum Lights DIY - Do It Yourself
    Last Post: 08-17-2015, 07:25 PM
  3. it is 3000 lumens or 3800 lumens?
    By Alwin.Wu in forum Lights and Night Riding
    Last Post: 12-17-2012, 05:54 AM
  4. Rubix - The Quad D-Bin P7 Light 3,600 lumens
    Last Post: 08-20-2011, 08:36 PM
  5. Led lumens, output lumens, hot lumens, cold lumens :)
    By Dominik.M in forum Lights and Night Riding
    Last Post: 08-15-2011, 03:48 PM
