quad cutter lens - broken- Mtbr.com
Results 1 to 8 of 8
    look what happened to me
    as a destroyer of optics myself
    What has done that
    Don't know. I got narrow optic and open my lamp to swap it and then saw it. I have removed that small piece with nail. Overheated? Overpressured? Bad quality? I thougt that led go first
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    Quote Originally Posted by frozen
    Did you clean it with any solvent (like alcohol, or...?). I've seen that happen a number of times due to cleaning. Because the plastic is so thick, there are a lot of internal stresses as it cools in the mold, and some sort of solvent weakens it just enough and it breaks. It is a really smooth broken surface, right?
    Sorry to see that happen...
    Reputation: HEY HEY ITS HENDO's Avatar
    any cracks in the other 3?
    ...Scun.thorpe, UK
    I cleaned it with isopropil alcohol, but at front where I left fingertip of AA glue, didn't touch the back. It cracks around all 4 necks, but pieces hold together, I pulled one out.
    Reputation: znomit's Avatar
    Yeah, that will wreck it (been there, done that). You must have got a bit on the rear too.
    Time to order another.
    Welcome to the solvent abusers club Frozen
    the solvent I used was a bit more aggresive and mine turned to crumbs in front of me
    I was stunned just watching it happen
