Protection question- Mtbr.com
Results 1 to 2 of 2
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    Protection question
    I'm rebuilding a dinotte 4-cell w/protection circuit board. I ordered 4 protected 18650s. Should I solder the board to the protected cells or eliminate it?
    I wasn't sure how I know if the protection board was "tripped" previously. If it was, is it forever tripped or can I reuse it?
    RAKC
    Reputation: tigris99's Avatar
    Replacing a welded pack cells isn't as simple as soldering. And the protection circuit is perfectly fine. But you ordered protected cells so no reason to reuse the board, you'll just create more resistance. The protection circuits are simply reset by charging the pack.
  1. Frame protection and fork protection tape
    By Roadking1962 in forum Pivot Cycles
    Last Post: 09-10-2013, 07:53 PM
  2. Replies: 12
    Last Post: 05-01-2012, 08:28 AM
  3. Maxxis Ikon EXO Protection Question
    By Taz8 in forum Wheels and Tires
    Last Post: 01-15-2012, 12:23 AM
  4. Protection... Bike Protection that is..
    By go1d1e in forum 29er Bikes
    Last Post: 04-30-2011, 01:41 AM
  5. 18650 Li-ions built-in protection question.
    By heniekkrol in forum Lights DIY - Do It Yourself
    Last Post: 02-23-2011, 07:33 AM
