Plexiglass front cover?- Mtbr.com
Results 1 to 10 of 10
    Reputation: robtarr's Avatar
    I am finishing up building my first light. It is basically the same design as achesalot's triple cree light, but my optics are round, not square. My question is, does anybody have any suggestions for something to cover the front to protect the optics from the elements?
    thanks,
    Rob
    You will loose quite a lot of light when you'd would use plexiglass. Coated glass would be a better solution, it will only be hard (harder than plexiglass) to find in the right dimensions.
    Use the plexi and you will be fine.
    Plexi has a higher abberation value than glass so there is some distortion of the light.
    Minimal when considering it is for a bike light and not the optics in a telescope.
    Same holds true for anti-reflective coatings. Minimal loss in bike systems.
    Anti-reflective coatings increase light transmission by a few percentage points due to decrease internal reflection. No so much that anyone would notice with a projected light.
    Plexi is cheap and easy to work with.
    Unless there is a drop in glass lens for you light I would stick with plexi. Most hardware stores sell it in small sheets. Score it with a razor knife and snap the plexi.
    Reputation: zen bicycle's Avatar
    1/8 or 1/16 polycarbonate (lexan)
    Look at www.smallparts.com
    http://www.smallparts.com/Clear-Poly...AF&pf_rd_t=101
    Can cut it with scissors and as long as it sits flush against the optics very little loss.
    Reputation: HEY HEY ITS HENDO's Avatar
    welders head mask clear protective lens, about 4" x 3" x 1/8"
    unbreakable, (lexan?) so you can easily cut/shape to what you need
    ...Scun.thorpe, UK
    Reputation: bumphumper's Avatar
    Jan 2009
    I've found that plexi scratches easily, but it is cheap and easy to replace.
    Recently I have used dismantled clear glass camera 'filters' intended for camcorders, they seem to start at about 1" upwards...also cheap at my local secondhand camera shop.
    There is a big difference between Plexi and poly. Plexi will scratch easily. Polycarbonate not so much.
    Carbon8er
    Reputation: El34's Avatar
    Jan 2009
    I bought a 3 x 3 square foot of Lexan (polycarb) at Lowes
    It's over with the house replacement glass
    They have small pieces also, like 5x7, 8x10, etc
    poly carb rules, I love it.
    At Work
    Reputation: sxr-racer's Avatar
    I dont run any on mine. No issues yet. 2nd season.
    I have to ditto the welders mask cover sheet. They come in small or large rectangles and are poly carbonate and nice and thin so the light gets through well. They are also very cheap. I payed around $2 dollars for mine.
