PCB question from existing battery pack- Mtbr.com
Results 1 to 8 of 8
    Reputation: ljracer's Avatar
    I have one of the old geomangear magicshine replacement batteries; that I finally opened up. Appears to have decent panasonic cells for the time circa 2011. There are two extra white wires on the PCB. Any thoughts as to what they are? Some balancing leads?
    Heres a pic for reference
    PCB question from existing battery pack-imageuploadedbytapatalk1442410533.006718.jpg
    PCB question from existing battery pack-imageuploadedbytapatalk1442410555.254221.jpg
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by ljracer View Post
    Looks like those two wires go to a thermal sensor glued on the side of one of the cells. Typically that's an added safety feature to keep tabs on the battery temperature during charging and throttle back the charging current if things get too hot.
    Reputation: bigflamingtaco's Avatar
    Oct 2013
    Yep, yes, and, definately those are the leads for the thermal resistor. Do not disengage until the bomb is armed.
    I will suffer no butt-hurt fools!
    Nov 2012
    Quote Originally Posted by bigflamingtaco View Post
    +1 ^^^
    Thanks for the responses! Any special order of disassembly? Im going to pull the cells out and replace.
    May 2005
    ...Some balancing leads?
    If I were rebuilding that pack, I'd add a balancing connector and charge with a hobby charger. I don't know about how heavily used that pack was, but it might still be going today if it had been occasionally balance charged.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    Good idea. Pack still works. Only with shorter run times.
    I'll do some searching on adding balance leads and which is a decent inexpensive hobby charger.
    May 2005
    I use my son's. I think it is a Turnigy 6 something. Works well, good price, easy to use. Have to get an old laptop power supply to power it. Pretty cheap at Goodwill or you can get a power supply for it from Hobbyking
  1. Noob battery pack question
    By velovite in forum Lights DIY - Do It Yourself
    Last Post: 10-17-2013, 07:34 PM
  2. Advice on battery purchase for existing light
    By punchy in forum Lights DIY - Do It Yourself
    Last Post: 09-23-2012, 04:47 PM
  3. Question about modifying battery pack (Magicshine clone)
    By trdi in forum Lights DIY - Do It Yourself
    Last Post: 09-07-2012, 06:32 PM
  4. Which battery for existing lights
    By likeaboss in forum Lights DIY - Do It Yourself
    Last Post: 09-07-2012, 12:05 PM
  5. pre-made battery pack vs. battery cell holders
    By Andy13 in forum Lights DIY - Do It Yourself
    Last Post: 01-28-2011, 11:58 AM
