PCB Battery overdischarge protection. Where can I buy one?- Mtbr.com
Results 1 to 14 of 14
    Reputation: james266's Avatar
    Hi,
    Im looking for a battery overdicharge protection PCB circuit to put on a 7.4V LiPo. It needs to have a max current draw of about 7A and no minimum. I cant seam to find one but Im sure they are somewhere.
    The only ones that I can find have a discharge protection to 2.3V which is wierd as LiPos shouldnt be discharged to below 2.8 - 3V and they wont recover if they go below 2.5V
    Anyone know where I can find one? Preferably somewhere that the postage to the UK isnt going to cost more than the board.
    Reputation: HEY HEY ITS HENDO's Avatar
    hi james, ..... here ya go
    ............7A. ???? jeez, what you running?
    http://stores.shop.ebay.co.uk/LEDSEE-electronics
    http://stores.shop.ebay.co.uk/LEDSEE...34Q2ec0Q2em322
    ...Scun.thorpe, UK
    Reputation: yetibetty's Avatar
    Great find Hendo, just what I've been searching for(but never found)
    Thanks Hendo but the 7.2V PCB has a max discharge of 3A. I need 6A for a dual P7.
    Got any more?
    Hi James,
    Ive got a few 2S 5A rated ones 4 each inc p & p & paypal
    Electric performance
    * Overcharge Protection voltage for single cell: 4.35V +/- 0.025V
    * Overdischarge Protection voltage for single cell: 2.3V +/-0.1V
    * Overcurrent detection Protection <= 5 A +/-1A
    * Short circuit Protection.
    Email me if youre interested
    I'm in the UK too
    Likewise, what do you want to run 7A min for?
    james, your dual P7 with a battery voltage in>7.5+v will pull less than 3Amps
    maybe you`r adding the 2.8A + 2.8A current??
    ...Scun.thorpe, UK
    Ok, well my setup is slightly different. Maybe Ive worked it out wrong but here goes...
    Its a project I started a while ago when the P7 first started to appear and I bought most of the parts and did the machining for the housing but never got round to finishing due to no time.
    I've got 2xP7 each driven independently by a KD P7 driver. The idea being that I can control each independently from a dual switch near my thumb as one will be a throw and one a flood.
    Each one has a Vf of 3.6V so in series 7.2V, 2.8A however if you use a 7.4V battery its lower limit is about 5.6V so you will never get the full runtime. So if I run them in parallel then you will only need 3.7V from the battery and you will see the full runtime but you pull 6A from the battery?
    Or have I missed something?
    Having just gone back and read the KD site, at 7.2V input the driver only pulls 1.6A and at 5.5V it pulls 2A so the max I will need is 4A
    Must remember to check ideas that I have late at night!! + =
    @smudge: Having recalculated , assuming Im now correct I would be intereseted in a PCB from you. 1 for now but maybe another one later if I need another pack. but can you please explain something to me.
    From everything I have read and to my knowledge (which I admit is limited) from using them for RC helicopters, LiPos, will not recover if they are discharged below 2.5V per cell and its recommended not to go below 2.8-3V to maintain a high cycle life. LiPos are more sensative to charging than LiIons and they are not meant to be charged to more than 4.2V per cell and I have seen some pretty explosive videos of overdischarged batteries and overcharging them and puffing before exploding!!
    http://www.youtube.com/watch?v=SQ0SNESIkWk
    How come then that all the PCB protection boards that I have seen only protect from 2.3V to 4.35V???
    The RC protection circuits (they beep/ flash loudly when you get close to low voltage) are all set at 2.8-3V. Are the RC guys just over delicate as they need to pull 20C from the battery or are the DIY lights just a bit close to line??
    James,
    Mail me youre address and i'll pop one in the post to you. Just drop a few quid in a local charity box and that will cover it.
    e-mail sent. Thanks
    Are you sure that you dont want me to donate to the Smudge Beer Charity?
    Does anyone have an answer to my voltage useage question though?
    Does anyone have an answer to my voltage usage question though?
    ............ which one?
    ...Scun.thorpe, UK
    question is in post #9!!!!!!!!!!!!
    The question in post #9 about the voltage that you should allow LiPos to be discharged and charged to.
    Is it safe to go down to 2.3V becuase from everything I can find 2.8-3V is the minimum.
    Sorry there are so many questions but like to understand "why" and Im a mechanical engineer not electronic so I could calculate the strength of the housing or the heat flow patterns but it takes a little longer work out the black magics of electricity bit
