Not so ugly lights!- Mtbr.com
Results 1 to 6 of 6
    Dec 2008
    Not so ugly lights!
    Hi guys.
    I have posted some work in progress shots of me new build.
    Donor torch from garage,2x P7 ubin's,kaidom 3 mode drivers,couple of old boomss that i got off troutie powered by 7.2v laptop battery(7.6 Aph will add to it to make 11v)
    Took a couple of beam shots but not finshed yet.
    Taken with Panasonic TZ5 on auto so not too good.
    Cheers
    Tommo.
    Go faster!
    Reputation: sergio_pt's Avatar
    nice lights!
    are you using the seoul P7 in series?
    Dec 2008
    Using a driver for each light,
    Need to up my Battery voltage to 11v approx because at the moment its drawing 1.6amps
    at 7.2v per light! if i up it to 11v its 1.15 so should get pretty good run times,plus i have 3 modes per light and will have the option to just unplug one.
    In theory i should have 1800 lum (before optics loss) and i am running a 480 lum headlight also.so should all light up the trails nicely.
    All i need now is to make a decent loom and source some inline switches (suggestions anyone?) to keep it all neat.
    Tommo.
    Dec 2008
    Anyone know of an inline switch i could use?
    Battery space has some good ones but i dont think they ship to the uk.
    Go faster!
    You need more amps to get those leds to give the full lumen power. whats the driver specs?
    you can search for electronic switches there's a lot to chose... maybe you can get it at a local store.
    Dec 2008
    They are being driven at 2.8amp,the drivers seem ok although 1 has just destroyed itself.
    They need heatsinking but its not easy finding a way of doing this.
    http://www.kaidomain.com/ProductDeta...ProductId=1866
    This is the driver.
