New 7-up XPH35 build- Mtbr.com
Results 1 to 7 of 7
    Reputation: deesta's Avatar
    So, after seeing kwarwick's triple mod here: http://forums.mtbr.com/lights-diy-do...35-993665.html, I decided that the XPH was the way forward for my new bar light.
    It'll be a 7-up board from Cutter wired in parallel and powered with a H6Flex @ 6.6a (if possible). Each LED should get just under an amp each so, theoretically, good for about 11k lumens.
    Managed to make a start on the housing yesterday and I think it should be OK for heat.
    A few pics:
    New 7-up XPH35 build-imag5096%5B1%5D.jpgNew 7-up XPH35 build-imag5097%5B1%5D.jpgNew 7-up XPH35 build-imag5098%5B1%5D.jpgNew 7-up XPH35 build-imag5090%5B1%5D.jpg
    Will update as the build progresses
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Looks nice! I like the beefy heatsink fins. For a light of that power I'm curious why there is doesn't appear to be an integrated shelf for the LED plate? Are you going to have a screw in pill?
    Quote Originally Posted by kwarwick View Post
    There's going to be a plate that sits, sandwiched, between the 2 halves. The LED's will sit on one side, the driver on the other.
    Quote Originally Posted by deesta View Post
    Ah, that makes sense. It will be important to have a very good interface between that plate and the body to ensure heat transfers efficiently... maybe some heatsink compound on the mating surfaces?
    Definitely looking forward to seeing your progress on this light.
    Yeah, that's the plan. Will put some on all mating faces to make sure it's a good interface.
    RAKC
    Reputation: tigris99's Avatar
    That case looks awesome, nice work.
    After doing some research for my stuff, found something important about dealing with heat issues:
    Raw aluminum is horrible at dissipating heat. Awesome direct transfer but radiating heat it sucks. So if you can, anodize the outside (remove it where your plate for the emitters will contact the housing) or simply use paint will decent emissivity. Will help alot with heat. Even clear anodizing will do as good as any other color.
    Good tip mate. Luckily we get stuff anodised through work so these will be getting done..
    Just need to work out a colour..probably black to match the bike.
  1. 4800 lumen 3up XPH35
    By kwarwick in forum Lights DIY - Do It Yourself
    Last Post: 01-25-2016, 03:42 PM
  2. niner build help newbie to build world
    By desflurane in forum Niner Bikes
    Last Post: 12-18-2011, 04:19 PM
  3. 1996 Dirt Research Kobuk Build (Updated build pics!)
    By fallenleafs in forum Vintage, Retro, Classic
    Last Post: 09-18-2011, 03:28 AM
  4. Soul Cycles Clydesdale Build: My First Bike Build
    By Shocker99 in forum Clydesdales/Tall Riders
    Last Post: 06-21-2011, 03:16 AM
  5. Yeti 575 2010 build Sram xo build
    By britishboy in forum Yeti
    Last Post: 05-02-2011, 04:28 PM
