Need a bottle of guidance for battery options- Mtbr.com
Results 1 to 11 of 11
    Need a bit of guidance for battery options
    Hello Gents,
    I have a tripple MC-E light coming from Deesta/Troutie. I need to get a battery pack that would last At least 2:30hrs on high. Could you guys please help me out on what type of battery configuration I should go with..
    Randomhead
    what driver does that have?
    Reputation: deesta's Avatar
    It'll be running off a maxFlex..
    You are going to want some thing like a 14.8 volt 5200mah pack for a good runtime
    maybe bigger but certainly not smaller.
    mind you dont usually run on full the whole time .
    So, you guys think this would work OK?
    Also, is there any need for a main shutoff switch?
    http://www.batteryspace.com/index.as...OD&ProdID=3658
    http://www.batteryspace.com/index.as...OD&ProdID=4463
    Quote Originally Posted by psylence
    Nope that one has a 12 volt regulater so is no good is there a similar one with out the 12 volt regulator .
    You dont need to worry about a switch it will have one and all functions are done in the maxflex software and when not using it you will unplug the battery .as it is not a good thing to store the light connected to the battery in case of accidental switch on which could lead to overheating or battery discharge.
    so then, this would be a winner?
    http://www.batteryspace.com/index.as...OD&ProdID=5164
    Troutie, what type of battery connector are you using for the light?
    That battery should be good
    Connector wise I am not sure yet we are looking at some new ones and I should have a sample soon
    or I can just leave a tail on the light for you to put a connector of choice on .
    I am no pro at this so excuse me if I give you the wrong info. I did however read on the maxflex tech docs that you shouldn't exceed 3amps. use it, don't use it..
    regards
    Thys
    So i was about to buy the battery i listed above and realized it's stupid heavy. at over a pound it is way too much. So that leads me to these bad boys:
    http://www.batteryjunction.com/tenergy-14-8v-4400.html
    http://www.batteryjunction.com/tener...-6600-pcb.html
    What runtimes would you guys guesstimate i would get with these using the 3 MC-e's on full?
    One Gear
    Reputation: .40AET's Avatar
