N00b needs advice. Re-assemble or replace?- Mtbr.com
Results 1 to 3 of 3
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    I had an unfortunate incident last night on a ride where the strap on the soft cordura pouch holding my batteries failed and the battery pack came off the bike. Here is the result:
    seeking directions on how to repair it, or if it should be replaced.
    The light is a "real" Yinding" from the group-buy last year and has worked flawlessly for probably 40 night rides, almost one a week since Jan '15.
    Aug 2014
    anyone? i mostly just need to know how to position the protection circuit on top.
    Shurely it can be repaired as long as you did not make any short that could fry the circuit.
    See the thread about batteries for example this one http://forums.mtbr.com/lights-night-...ce-995303.html and
    http://forums.mtbr.com/lights-night-...gb-982688.html
    You would need to tear down black foil around the pack (just one long cut on the oposite side between cells). You can duct tape it back later.
    Make better, larger and focused pictures of your protection circuit from both sides so we can help further. Also new pictures of unwrapped pack would be good.
  1. Fork help for 29er n00b (not mtb n00b mind you..)
    By idrinkwater in forum 29er Bikes
    Last Post: 07-30-2014, 05:26 AM
  2. Advice On Mountain Bike Setup (N00B Alert)
    By bklynjames in forum Beginner's Corner
    Last Post: 05-11-2014, 06:06 PM
  3. Clipless pedal advice for n00b
    By Aquayonex in forum Clydesdales/Tall Riders
    Last Post: 05-02-2012, 06:25 AM
  4. Replies: 4
    Last Post: 03-02-2012, 07:55 PM
  5. N00b reporting in with first n00b question - cranksets
    By iltridente in forum Beginner's Corner
    Last Post: 12-28-2011, 01:09 PM
